19x8.5 +42 on sedan?
Old Mar 14, 2006 | 12:50 PM
amG35's Avatar
amG35
Question 19x8.5 +42 on sedan?
Any sedan owners running a 19x8.5 wheel in a +42 offset? Any clearance and/or rubbing issues? Can you post some pics please? Thanks
Old Mar 14, 2006 | 07:04 PM
gdup35sedan's Avatar
gdup35sedan
I'd advise against it. like the guys over on g35driver said, 35 or 38mm. intgr8tr is the only one with a +42 and its pretty damn close to the suspension.
-GP-
Old Mar 15, 2006 | 01:05 PM
louielou's Avatar
louielou
Im running +46 and it just fine...its really close but nothing a 5mm spacer can't fix.
Old Mar 16, 2006 | 09:24 PM
Triple8Sol's Avatar
Triple8Sol
From what I've seen, 35mm would be best for appearance and fitment...
Old Mar 21, 2006 | 04:40 AM
inTgr8r's Avatar
inTgr8r
+46 x 8.5" sedan rim???
I'd have to see it to believe it.
Like gdup35sedan said... ET 42 is tight to the suspension (no rubbing)
5mm further out would be ideal.
I have 5mm spacers, just haven't gotten arround to putting them on yet.
Old Mar 21, 2006 | 09:39 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
19x8.5 with 42+ will work fine. You can go as low as 30 and up to 45 with that size of wheel.
Old Mar 21, 2006 | 01:42 PM
Auto RnD's Avatar
Auto RnD
normally w/ g-sedans we tend to go with 9+45 and 10+45 and they are still very conservative
Old Mar 21, 2006 | 03:09 PM
godmans's Avatar
godmans
+35 with a 8.5mm, you might be asking for rubbing in the outer edge, but it also depends on your choice of tires
Old Mar 21, 2006 | 05:24 PM
vrsc's Avatar
vrsc
I am running 19x8.5 with a +45 offset with my Volk GT-V's on my 2005 Sedan. I was directly advised from Makin that this would be the best offset for me. They look and fit fine but if +38 offset were available in my size and style then I would have went with that.
Old Mar 21, 2006 | 06:09 PM
Endless G's Avatar
Endless G
How much lip can this setup have?!?!
Old Apr 8, 2006 | 01:10 PM
az1anbeethoven's Avatar
az1anbeethoven
I have +35 with 245/35/20 and its not even close to rubbing ...anyways, +42 will be fine for the sedan no problem~~
Old Apr 8, 2006 | 01:53 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
You can run as low as 30mm offset with a 8.5 wheel without a problem.
9.5 wheel 42-45offset is optimal. But you can run 38+ if you roll the fender slightly.
Old Apr 8, 2006 | 05:06 PM
Built2shredZ's Avatar
Built2shredZ
here's what im running
Old Apr 9, 2006 | 01:19 PM
FenixL1P's Avatar
FenixL1P
so what spacer should i use for my m45 sport rims (19x8.5 with 50mm offset) so that there is no rubbing?
Is it possible to match what vrsc's comment about his volk gt-v's?
50mm offset with 5mm spacer should get me the 45mm right?
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
May 30, 2017 03:28 PM
Alexreyes
Sep 30, 2015 11:30 PM
