Rear Seat removal help
Old Apr 27, 2007 | 09:29 AM
myGspot's Avatar
myGspot
Default Rear Seat removal help
I need help removing rear seat (the portion you sit on) not the back. I read the service manual and it says you have to lift and pull... but no matter how much i try i cant get it.
Anyone know how to do it or done this that can help me out.
Is it even possible just to remove the seat portion without removing the back part?
help me please!!!
Old Apr 27, 2007 | 10:01 AM
06Gee35's Avatar
06Gee35
You can remove the seat bottom without the back. There are two clips which hold the seat down to the bottom. They are located in the left and right side of the seat cusion. Grab the cusion near the clips and pull up while pushing the seat cusion towards the rear of the car. The clips should pop and the cusion should come out. Don't be afraid to use a little force. I also believe there is a bolt (10mm?) in the middle between the back portion and the rear cusion, this keeps the rear seat cusion tied down. Loosen that up and it should be out in no time. Hope this helps.
Old Apr 27, 2007 | 10:34 AM
myGspot's Avatar
myGspot
where is that rear bolt located... is it in the trunk or under a mat somewhere?
thanks
Old Apr 27, 2007 | 07:40 PM
06Gee35's Avatar
06Gee35
Just looked at the service manual there just 2 clips located in the front edge of the seat near the corners that hold the seat down. Just use a little force and they will pop off the retainers.
Old Apr 27, 2007 | 11:10 PM
myGspot's Avatar
myGspot
i swear i either have some bad luck or i am just completly stupid.....because i still cant get the seat off.
i pulled and pulled and pushed... and the seat is still there.
Old Apr 28, 2007 | 06:07 AM
bassholic's Avatar
bassholic
you will not get thagt damn seat out. remove the rear top by undoing the bolts in the rear corners of the seat when you fold it down. from there you can left the bottom cushiopn up. i spent a long time tugging at the bottm as i was trying to run wires
3vilbunny
Jul 18, 2017 05:10 PM
