radio reception
Old Jul 13, 2011 | 07:39 AM
cc1012's Avatar
cc1012
Default radio reception
Im posting here because g35driver is basically useless.
Im not one to start a thread. Ive done much searching and maybe im not searching the right key words but I havent come up with anything. My G is 2007 coupe with 70k on it (premium package and nav) and Ive had it since new. I have read about what tints can do but I got the tints 68,000 miles ago. With in the past 2 weeks the radio reception has been awful. Some station will be fuzzy and some wont even come in sometimes. How should I troubleshoot this problem? Where should I start?
Old Jul 13, 2011 | 08:46 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
There's not a whole lot that can be causing issues. What antenna are you running?
Old Jul 13, 2011 | 08:51 AM
cc1012's Avatar
cc1012
stock antenna.... have not touched anything in the car. Car is bone stock. Could some of the connections to the antenna have come loose?
Old Jul 13, 2011 | 09:04 AM
Vivid Racing
Vivid Racing
They could have, but I'm going to assume it's your antenna amp aka antenna booster.
On your left side (Drivers side for us in the USA), pull the plastics off the trunk area. There's a box labeled Clarion. See if it's getting power. It should have power when the key is on. If it's getting power, then check antenna connections.
Assuming your interior has never been torn apart, I don't think anything would be pinching the wire so there's really only the connection @ the antenna, the connection at the antenna amp, and connection at the radio in the dash.
Old Jul 13, 2011 | 09:13 AM
cc1012's Avatar
cc1012
where are the antenna connections? one in the back of the radio? and wheres the other?
Old Aug 30, 2011 | 08:12 AM
Steezy's Avatar
Steezy
Is this down by where the bose amp is? or on the trunk lid plastic?
Old Aug 30, 2011 | 10:00 AM
Steezy's Avatar
Steezy
hmm... is it a stock HU? maybe you need a new HU, those things go out quite often, usually it starts w/ the radio then the CD player/ac controls n then you lose it all. invest inna double din setup
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Sailors350Z
Sep 25, 2015 08:21 AM
Dr Bonz
Nov 29, 2003 09:12 PM
mcclaskz
Nov 13, 2002 10:17 AM
