help with pulley belts !
Old Jul 13, 2004 | 03:25 PM
GMADD's Avatar
GMADD
Default help with pulley belts !
Well,
I just came back from the dealer today.I had them check my pulley belts.After my crank pulley and NEW belts install, they started making a whistling sound,so I told them to check it out. Well the dealer said that I need new ones b/c the ones I had were used up. So now I need to order other ones !
Is this normal after only 1500 miles ?
Should I keep the pulley on or put back the stock one?
What should I do ?
Old Jul 13, 2004 | 08:56 PM
scz's Avatar
scz
Default Re: help with pulley belts !
It is not very likely, but in the case that the belts were to tight when the pulley was first installed, the belts could be stretched out. If that is what the tech said, it wouldn't hurt to buy another set of belts anyways just to check it out; they are cheap. Plus it is always good to have an extra set of belts on hand.
Old Jul 17, 2004 | 10:37 PM
350xfire's Avatar
350xfire
Default Re: Re: help with pulley belts !
Just FYI on this issue, I just installed headers on my G Sedan and I found that the A/C belt had a split section about 2" in lehgth down the middle of it. My car has 30,000 miles on it.
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
