Anyone withTein Flex and EDFC setup?
Old Aug 6, 2004 | 06:46 PM
SkyG35's Avatar
SkyG35
Default Anyone withTein Flex and EDFC setup?
Planning on getting this set up for the suspension. What you paid for the labor and where did you mount the controller? Pictures would be wonderful. Thanks for the help.
Inputs on before and after?
Old Aug 7, 2004 | 08:03 AM
AXA_G35's Avatar
AXA_G35
Default Re: Anyone withTein Flex and EDFC setup?
I'm using that same set-up.
I got mine from RPM Motorworks in Fullerton, CA and got it installed there as well. Can't disclose the price, sorry.
You can find pictures of the set up at my homepage.
www.cardomain.com/id/axa_g35
Old Aug 8, 2004 | 06:48 PM
Import-Tooner's Avatar
Import-Tooner
I have seen people mount their controller where the ash tray is in the center console. Looks really good.
Old Aug 9, 2004 | 10:37 AM
AXA_G35's Avatar
AXA_G35
unless you cut the back side of the ashtray bin, it's too shallow for the EDFC to go in...i didn't mount it there because i didn't want to hack the console too much.
but yes, it would look a lot better as long as you can do a clean install.
Old Aug 29, 2004 | 06:27 PM
Eagle1's Avatar
Eagle1
I put the unit in the roll top cubby. you do have to cut a hole in it, then mount it at about 75 degrees towards you (not quite vertical). It is easy to see and program from the driver seat, and the sliding top keeps it out of sight if you so desire.
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
