Are my O2 sensors shot?
A few months ago I installed headers and test pipes and ran that setup for about a week. It was too noisy for me, so I put the stock cats back on and have been driving it that way ever since.
Immediately after the initial header/testpipe install, I got an SES light. I cleared it using the TS tapdance method numerous times, but it always came back and stayed on. I figured when I put the cats back on and immediately reset the ECU, I wouldn't get that damned SES light....wrong. It refuses to go away!! I've reset it numerous times, and it goes away just until I finish driving and shut off the car. Immediately thereafter when I start the car, the SES light comes on again!! I'm about to go out and buy new O2 sensor for the cats, but I want to get some opinions and insight from the members here. Did I damage the sensors when I ran the testpipes? Whats going on?
I have a 2003 Track with JWT Popcharger, topspeed headers, and UR crank pulley (if it matters).
Spend a couple hundred bucks and get a code reader/dataloger.
ztropic
If you can do the tap dance, just dont do the last 10 second bit & your ECU is now in diagnostic mode. Just count the check engine flashes.
EG: 10 followed by 3 then 3 then 5 = DTC 0335. crank angle sensor
