throttle body removal tips
Old Apr 27, 2005 | 07:23 PM
jkoc's Avatar
jkoc
Default throttle body removal tips
hey guys...
i'm having a hard time unscrewing the 5mm allenkey bolts from the throttle body.. its frikken tight as hellllllllllllllllllllllllll
any tips on how to get these 4 bolts off ?
Old Apr 27, 2005 | 09:43 PM
Z BOY's Avatar
Z BOY
ummm, a hammer?......i mean, hammer on the lever arm.
Old Apr 27, 2005 | 10:36 PM
jkoc's Avatar
jkoc
sick
i managed to get them off but one of the bolt's 5mm allen socket head is totally destroyed.
the bolts seem to be 70mm M6 bolts (with a a5mm allen socket head) with lock washers... i am thinking of replacing these annoying bolts with regular hex-head 70mm M6 bolts with flat washers --- does anyone foresee a problem with this?is it a bad idea? why did nissan use these freakin annoying allen key bolts??
Old Apr 27, 2005 | 10:43 PM
Z BOY's Avatar
Z BOY
i think someone just cranked on them too hard with install. never had that prob with mine. i would use oem ones, but not use threadlock or overtighten them.
Old Apr 28, 2005 | 05:16 AM
2003z's Avatar
2003z
when removing them, I use vice grips on the short end of the allen wrench for leverage.
You will have no problem replacing them with standard bolts of the same length, if you can find them.
Old Apr 28, 2005 | 05:31 AM
jkoc's Avatar
jkoc
yeah i had M6 70mm bolts with lock washers left over from my AAM spacer install which died on me. the 70mm bolts are exactly the same thread and length as the retarded allen head bolts...
thanks.. looks like my crawford cast plenum is gnona be installed by tonight!
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
