HKS SSQV question - what intake manifold source?
Old Jun 8, 2005 | 12:45 PM
gringott's Avatar
gringott
Default HKS SSQV question - what intake manifold source?
The instructions for the HKS SSQV BOV call for a connection to an intake manifold source such as OEM (factory) fuel pressure regulator or a pressure fitting after the throttle body.
Has anyone hooked up this BOV to a twin turbo kit using the stock intake manifold? If so, and it is working properly, what line did you hook it to? A picture or diagram would be very helpful as I don't want to make a mistake.
Thank you for your time.
Old Jun 8, 2005 | 12:52 PM
1 2 NV's Avatar
1 2 NV
If I am understanding you r question correctly, there is a fitting on the front left of your plenum you can hook you b.o.v. vaccum line to. Just pull the cap off it and slide the vaccume line on it. You cant see it unless you take the plastic plenum cover off.
Old Jun 8, 2005 | 12:57 PM
gringott's Avatar
gringott
I saw that line - has a black cap. No problem using it for this purpose? Thank you sir.
Old Jun 8, 2005 | 01:01 PM
1 2 NV's Avatar
1 2 NV
Nope, it shouldn't be a problem at all. Thats where I have mine hooked up to.
Old Jun 12, 2005 | 08:27 PM
Rayden2001's Avatar
Rayden2001
Doesn't your vacuum line that comes from your fuel pump hook up to there now???Mine does. I'm gonna install my bov this week.
Old Jun 12, 2005 | 10:52 PM
gringott's Avatar
gringott
No. I don't know where that line is hooked up. I will look when it stops raining.
lapham3
Oct 7, 2022 03:15 PM
