Test Pipe Roll Call
Old Jun 19, 2005 | 08:20 PM
zownz's Avatar
zownz
Default Test Pipe Roll Call
How many of you with test pipes did get a CEL?
Please provide year of vehicle as well..thank you=)
Old Jun 19, 2005 | 08:41 PM
uplz4588's Avatar
uplz4588
04.5 got CEL. then never came back after i put on HELP nonfouler mehtod
Old Jun 19, 2005 | 08:42 PM
287HP's Avatar
287HP
03, No CEL!
Old Jun 19, 2005 | 08:48 PM
zownz's Avatar
zownz
where did you get that or how do you do it?
Old Jun 19, 2005 | 08:54 PM
raptorbh12's Avatar
raptorbh12
i have an 04 and right after i got my helix pipes on, i got a CEL. even after reflashes and ecu resets it comes back on after some driving.
Old Jun 19, 2005 | 09:04 PM
uplz4588's Avatar
uplz4588
all you need are two packs of nonfoulers to get rid of the SES that you WILL get with an 05.
HELP! Spark plug non fouler. Part 42002 for 3.99 from autozone.
They are a 2 pack. Get two packs and drill 2 of the nonfoulers out with a 1/2" drill bit. screw the NON driilled nonfouler into the test pipe. Then screw the DRILLED nonfouler into the non drilled fouler - install your o2 sensor into that. You will be SES light free and it will cost you less than $10 and about 1/2 hour of time.
Old Jun 19, 2005 | 09:12 PM
mgl's Avatar
mgl
03 no CEL.
Old Jun 19, 2005 | 09:28 PM
bhk1004's Avatar
bhk1004
no cell for a few months... then I Got a cel, then i did the ECU reset and its been gone and no more, early 04
Old Jun 19, 2005 | 09:44 PM
narkotic's Avatar
narkotic
04, xerd testipies and APS TT. No CEL, but tons of rasp.
Old Jun 19, 2005 | 09:46 PM
r.c.y.k.'s Avatar
r.c.y.k.
is it actually true that 03 with testpipe would not throw a CEL? since i have a 03 with testpipe, but i got CEL...
Old Jun 20, 2005 | 02:04 AM
sein's Avatar
sein
I only bought one pack and drilled out the holes and my ses light has not came back! I have a 04.
Also, if you have a problem doing the ECU reset that TS provides after you do the install go back to autozone give them you ID and they will give you the little device so you can reset it yourself. It only took me 1 min or less to do it.
OH, I almost forgot, I have helix test pipes.
Old Jun 20, 2005 | 10:15 AM
myehrick09's Avatar
myehrick09
'03 Touring w/ Xerd Test pipes. No cel but loud as **** w/ a touch of raspiness when you hit 4000 rpm
Old Jun 20, 2005 | 10:21 AM
Badmonkey's Avatar
Badmonkey
03, I got a SES light about a week after installing my test pipes. I reset it with the throttle reset procedure, it never came back. It's been about 4 months now.
Old Jun 20, 2005 | 10:27 AM
hfm's Avatar
hfm
LaBree Motor Sports testpipes with resonators with no CEL for 03.
Old Jun 20, 2005 | 10:28 AM
Gman2004's Avatar
Gman2004
Me too....04.5 got cel. Used nonfouler method.
Old Jun 20, 2005 | 10:30 AM
JzG35's Avatar
JzG35
'03 no cel
Old Jun 20, 2005 | 10:38 AM
DrVolkl's Avatar
DrVolkl
Early 03 with Kinetix Test pipes, on for almost a year now. NO CEL ever.
Old Jun 20, 2005 | 10:43 AM
gringott's Avatar
gringott
03, TT, Xerd, NO CEL
Old Jun 20, 2005 | 02:06 PM
onyx350z's Avatar
onyx350z
'03 with Labree resonated testpipes - no rasp, did have SES light before had the bung holes drilled into the pipes for the O2 sensors and no light since.
Old Jun 20, 2005 | 04:00 PM
zownz's Avatar
zownz
thank so much for the input
looks like so far all 03 no cel
and 04 did have cel...gues i have to get that stuff from autozone and fix it up
whats a fouler bt w
