Will the crank pully help
Old Jul 27, 2005 | 09:53 AM
ZlleH's Avatar
ZlleH
But doesn't wieght give you momentum? Once you get started with that heavey wieght, the momentum helps to add more power... So does your below analogy really cover the momentum part?
Originally Posted by JonathanAboona
The thing I tell my customers is to sit in the car and try to remember what the car feels like prior to the install. Count in your head how long it takes to get to redline from a 30mph roll and so on. or count how long it takes for the rpms to fly up and drop when you are in neutral. Then after do the same. A good analogy is a runner with weights on his leg. He uses the same energy when running both ways but without weights he can lift his leg faster for his next stride.
lolwatbro
Oct 9, 2021 04:58 AM
B Esquire
Sep 24, 2015 07:52 AM
Shane86
Sep 17, 2015 05:33 PM
