10 hp for under $200.00
I didn't even need the spacers for the strut bar with my AAM plenum spacer. The stock strut bar has a **** load of adjustability and a few turns later I had 1/4 inch of clearance.
"However I did have to remove the two rubber inserts on the hood to clear the strut bar when I close the hood. "
You both have 2004's so all dimensions/clearances on the car are the same SO did you have to remove the inserts like lunartick13 did?
General question to anyone who is reading this:
Any opinions on the AAM plenum spacer vs the Crawford Plenum?
Thanks
Originally Posted by lunartick13
IMO these are simple inexpenssive mods and I think I am running about 310 hp at the crank..
Plus, my 2005 only has 4500 miles on it.
I really like the looks of your engine bay.
Where did you get the Polished Upper Plenum as well as the pipe for the air cleaner?
Thanks
Originally Posted by tmb
I guess you can tell that I have done Zero mods to my car (beyond replacing the crappy audio system) so I am carefully moving forward on mods.
Thanks
Thanks
Originally Posted by MySunset350Z
whats it cost to polish the plenum? looks sweet. nice engine bay.
Originally Posted by Kaitain
Keep in mind these don't work on 2005's because there is just about no space available to raise the plenum; go look.
