Does your exhaust/sway combo creak?
Old Dec 16, 2005 | 08:37 AM
liudacris's Avatar
liudacris
Default Does your exhaust/sway combo creak?
I originally wanted Borla TD exhaust and a sway (not sure which), but I have heard of some people complaining that fitment wasn't perfect and there would be creaks, like how the chassis wasn't meant to carry TDs. So now I'm thinking about Nismo Exhaust + Sways (Still good, but not first choice) just to make sure it has perfect fitment.
So i just wanted to find out what combos are you guys running and if there are any "off noises" either from the exhaust alone, sway alone, or the combo of both
Old Dec 16, 2005 | 09:08 AM
Aftermarket dual exhaust is routed the same under the car as the OEM exhaust:
Drivers side: under the anti-roll bar
Passenger side: over the top of the anti-roll bar
An after market anti-roll bar will be shaped similar to the OEM bar. If it will clear the OEM exhaust, it will also clear after market dual exhaust. I don’t see a problem.
Old Dec 16, 2005 | 09:19 AM
liudacris's Avatar
liudacris
Thanks for the pic and reply.
I heard of people complain about fitment noises (or maybe it was from something else, but they said it was from fitment) before and don't wanna spend $1200+ on something that doesn't fit right.
Old Dec 16, 2005 | 12:20 PM
DG350Z's Avatar
DG350Z
My Borla TD hasn't had a problem with leaks, but sometimes when the car is extremely cold the exhaust will rattle (I suspect it is hitting against the sway). After it warms up though its completely gone, so it isnt much of an issue.
Old Dec 18, 2005 | 02:55 AM
liudacris's Avatar
liudacris
why would it rub when its cold, but not when its warmed up?
Old Dec 18, 2005 | 03:43 AM
froggy's Avatar
froggy
The rattle when cold at start up and during first few minutes seems common, Invidia N1 here. Resonance,stainless steel...
May 12, 2016 07:42 PM
juang20
Intake
Sep 7, 2015 05:37 PM
goracer
Jan 14, 2003 02:45 PM
