What is??
Old Dec 27, 2005 | 08:49 PM
thReeFiFtee's Avatar
thReeFiFtee
Default What is??
I might sound very stupid and dumb asking this question but i tried the search can't really pull it up and get the answer..
what is a plenum spacer.. and what purpose does it serve?
Ahh i feel stupid.. lol.. Thanks
Old Dec 27, 2005 | 09:22 PM
Blurr350z's Avatar
Blurr350z
A plenum spacer is a part, or a spacer, that fits inbetween the intake plenum and the intake manifold. The whole point of using one is to correct the inbalance in the airflow between the intakes for all 6 cylinders. The stock plenum was engineered with a fault, in that the front two cylinders do not receive as much air as the other 4. The spacer helps to correct this, and in theory gives the motor the power it SHOULD have.
Plenum spacers are also cheap alternatives to aftermarket plenums. I have a spacer and it works great. Not too expensive, and it keeps the factory strut tower bar. Some aftermarket plenums may work better (crawford, kinetix, etc.) but they are more expensive, and some require an alternate strut tower bar (one that clears the new plenum). Hope that cleared some things up, next time just search and read and Im sure you'll find the answer.
Old Dec 27, 2005 | 10:16 PM
onebadfyvo's Avatar
onebadfyvo
Hey Blurr350z, are there ##'s available for the plenum spacers/aftermarket plenums as far as hp gain and cost? Thanx. Also, I see you have the AAM spacer. Would you get it again or get something else (in hind sight)? Thanx.
Old Dec 28, 2005 | 09:30 AM
raptorbh12's Avatar
raptorbh12
all the spacers do the same thing and are practically identical, Skunk2 makes a cheaper one which i would have gotten if it was out when i first bought mine. Ide say they give you about 5hp?
Old Dec 28, 2005 | 11:31 AM
Besides these 95 posts...
https://my350z.com/forum/search.php?searchid=761519
...I couldn’t find anything either.
Old Dec 28, 2005 | 03:15 PM
thReeFiFtee
thanks. what link is that david nothing came up..
Old Dec 28, 2005 | 07:15 PM
My dumb. I have to get my links straight. Try this https://my350z.com/forum/search.php?searchid=763115.
