Helix Cats = cracked
Old Mar 22, 2006 | 10:53 AM
Zquicksilver's Avatar
Zquicksilver
IMO, a (U-bolt with rubber flex connection) at some stratigic points would help...
I'm basically going to re-anaylize my setup when the Nismo exhaust goes on in a few weeks. I'll figure out what needs to be done at that point. So far things seem to be holding up just fine.
Zquicksilver
Old Mar 23, 2006 | 01:19 PM
BlueBlur's Avatar
BlueBlur
It is an issue on both OEM & after market because it doesn't have any support as you pointed out in the middle on the exhaut flow.
I had the Nismo exhaust & OEM cats & the OEM cats cracked all the way around at the weld to the point the mounting piece on the side of the cat that connects it to the "U-bracket" was completely seperate from the cat itself & left a hole the size of a Quarter. That is why I went with the Crawfords.
I didn't see any play in the "U-bracket" under the car..just to help you align the bolt into the hole.
It is a flaw in the design as a whole.
Old Mar 23, 2006 | 03:41 PM
sisco534's Avatar
sisco534
Custom dual ehaust takes some of the presure off , works well for me ....so far
51k miles
daily driver
Old Mar 23, 2006 | 04:55 PM
ZinMiami's Avatar
ZinMiami
How is that?
My Borla True Dual doesn't help any based on it's use of OEM hanger positions only.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
Twenty4
Jan 17, 2016 01:20 PM
Li1ag
Sep 28, 2015 02:07 PM
