you have to spray break free or wd40 on the rubber pieces.(i used a pry bar to get mine off)theres also a little green strap thats connected to the exhaust.hope this helps.
Just for reference in case this is found in a search,
Don't use WD-40 on rubber parts, use a silicone base lube.
Also,
The rear can is quite easy to remove, laying under the car, push off the forward 3rd hanger first, then laying flat use a pry bar on the back two using the exhaust tubes as leverage and they will pop right off.
