Z with Pop-Charger...READ THIS....TIP
Old Jun 30, 2006 | 09:11 PM
Zmazing03's Avatar
Zmazing03
Wow, you posted how to pop your clutch? I hope this was not a new technique you just learned.
Ah, what? Popping the clutch? Whats this have to do with popping the clutch?
Old Jun 30, 2006 | 09:14 PM
rookie's Avatar
rookie
That's what you're doing when you put it back into gear and let go of the clutch.
Old Jun 30, 2006 | 09:17 PM
Zmazing03's Avatar
Zmazing03
Yes I am aware of what popping the clutch is..I've done it with dead batteries before.
And I assume you were referring to the poster up above, which is why I was confused.
Carry on.
Old Jun 30, 2006 | 09:30 PM
Originally Posted by VN_350z
why not, let's say you accerate right before you exit, i usually put it in neutral entering the exit.
That sounds like a recipe for disaster. The front end is plowing in the turn. The rear tires have no traction.
How about:
a. Brake
b. Downshift
c. Accelerate through the turn.
Old Jun 30, 2006 | 09:34 PM
Z4Zoro's Avatar
Z4Zoro
Originally Posted by uncutZ00
best thing to do is to not get a pop charger... what the hell is that thing anyways? thers like 0 HP gain and it looks like a *****.
Not sure what pop charger you are looking at. Has been dynoed for 6.5. And mine does not look like a ***** .
And the gains are similar to any other short ram intake. Also similar to some cold air intakes.
What intake do you have?
rookie's Avatar
rookie
If you want to coast so much maybe an auto would make more sense, what happens if something jumps out in the road as your in neutral coasting, accelerating and taking evasive actions to not hit it is not an option unless you have cat like reflexes to pop it back into the right gear for enough power.
Old Jun 30, 2006 | 10:37 PM
VN_350z's Avatar
VN_350z
Originally Posted by Zmazing03
Lol. I am fully aware of this. I am just trying to clarify that if it does do it, does it ONLY do it when put in neutral after 90, OR, does it do it say, when you shift and are off the gas for a second at higher speeds?
Sorry for all the Q's, but I seriously considering the PC within the next month.
Just put ur car in 5th gear, WOT until u pass 95+, put it in neutral right away(release clutch) and let it coast.....let us know.
I just tried my car again on the way home from my parents' home, it happens again
Old Jun 30, 2006 | 10:46 PM
steakpinoy's Avatar
steakpinoy
My friend used to have that stalling problem after installing his Pop Charger. We resetted his ECU (using the Technosquare site's method) and there have been no problems ever since.
Hope this helps.
Old Jun 30, 2006 | 11:09 PM
3FITTTY's Avatar
3FITTTY
my Z coats just fine...get yours checked out man..
Old Jun 30, 2006 | 11:21 PM
VN_350z's Avatar
VN_350z
Hope this helps.
How did it stall?
Old Jul 1, 2006 | 12:41 AM
roast's Avatar
roast
Remind me to never, under any circumstance, ride with you.
Old Jul 1, 2006 | 01:07 AM
Z4Zoro's Avatar
Z4Zoro
I have the pop-charger. So far it seems like a decent product. If you think about it there is still alot of heat developing with the heat shield. After a nice drive, I pop the hood and the heat shield is hot. I am sure this heat shield is not enough protection for the filter. I am truely thinking about the nismo or aem
intake.
Or maybe get the air duct system like kandN uses.
Old Jul 1, 2006 | 01:14 AM
roast's Avatar
roast
Stock airbox + drop-in for the kill.
Old Jul 1, 2006 | 07:07 AM
m1james@bellsou's Avatar
m1james@bellsou
...this method uses up your brakes more. Not sure why you would do this unless you're going to take a spark plug reading at the end of the ramp. You might want to consider a good performance driving school so you better understand driving dynamics.
Old Jul 1, 2006 | 07:29 AM
m1james@bellsou
....remove a perfectly functioning intake and replace it with one that gains nothing and causes problems
hmmnnmm
Old Jul 1, 2006 | 09:20 AM
zdrift78's Avatar
zdrift78
no problems with my stillen "intake"....which is basically the same thing as the pop charger...kinda weird!
Old Jul 1, 2006 | 09:54 AM
Travisf@i-a-v.c's Avatar
Travisf@i-a-v.c
Pop charger, good. No problems. Better note and 4 mo' hp. Coasting in neutral, esp at high speed, bad.
Old Jul 1, 2006 | 10:06 AM
  #38
Sunset350ZR's Avatar
Sunset350ZR
So the only time the stall is happening is when the car is left in neutral or will it stall during a slow gear change as well? I can imagine a slow gear change, but for the life of me don't understand how you guys gathered enough people that put the car in neutral at 90 mph to find out there was a problem.
M
Old Jul 1, 2006 | 10:16 AM
  #39
VN_350z's Avatar
VN_350z
I did an ECU reset by disconnecting battery and slamming on the brake several times this morning. My plan is to drive for few hundred miles to see what ECU does...it may learn maybe....i'll findout
Old Jul 1, 2006 | 10:19 AM
  #40
VN_350z's Avatar
VN_350z
hmmnnmm
There are serveral dyno done by some magazines and it gains 5 whp. Do so search. Mine feels louder and throttle response way better than stock...love it. I think I can live with not being able to coast my car at high speed
