DIY Plenum spacer ???
Old Aug 18, 2006 | 01:33 PM
Minda's Avatar
Minda
Default DIY Plenum spacer ???
Guys, forgive me if this sounds stupid, but has anyone tried to make a plenum spacer? Ican't find anything on the forums
It look pretty simple stuff, to justify >200 bucks...
With some patience and right tools it should be possible to cut the spacer from a sheet of fiberglass or some other material (teflon anyone).
Any reasonable thoughts appreciated.
Old Aug 18, 2006 | 01:35 PM
buffmanjeff's Avatar
buffmanjeff
I dont mess with performance parts. Spend the extra money and be safe with it. More power to your idea though...
Old Aug 18, 2006 | 01:51 PM
teh215's Avatar
teh215
If you try it, I wouldn't use anything other than aluminum or some other metal. The vacuum pressures _may_ destroy fiberglass.
Old Aug 18, 2006 | 02:05 PM
Minda's Avatar
Minda
I believe, it shall make sense for the spacer to be out of some sort of plastic, since upper plenum would be thermally isolated - cooler air -> more gains.
Teflon should be ideal material here, but getting a thick teflon sheet of proper size may be an issue.
Old Aug 18, 2006 | 02:38 PM
kpiskin's Avatar
kpiskin
The Kinetix plenums have been known to melt even though they are made of heat resistant plastics. I'd avoid fiber glass or plastic of any kind and go with machined aluminum. Aluminum is a good heat sink.
Old Aug 18, 2006 | 05:33 PM
jondimellow's Avatar
jondimellow
aluminum can also be a good heat conductor.
Old Aug 19, 2006 | 12:08 PM
Minda's Avatar
Minda
But that is exactly why I think plastic would be better. If the upper plenum stays cooler, it may help keep the incoming air cooler.
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
