idling problem
Old Sep 15, 2006 | 04:57 PM
oneton's Avatar
oneton
Default idling problem
Need some suggestions. I just installed a Crawford plenum (black one) and having some major issues. When I go to start the car it will start, stumble at low RPM and then die. If I try to give it any gas the car will not respond. When it dies I hear a phssstt sound. I have triple checked all the vacuum lines and connections. Everything is tight and connected. Any ideas?
Old Sep 15, 2006 | 05:46 PM
oneton's Avatar
oneton
I did so more research and found out that I did something I probably should not have (removed the TB harness). I have tried following the ECU reset procedures and still have the same problems. Any ideas on what to try next? I have done numerous searches and coming up with nothing.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
