motordyne plenum spacer loctite?
Old Oct 14, 2006 | 08:31 PM
dragonbz99's Avatar
dragonbz99
Default motordyne plenum spacer loctite?
i didnt use the loctite on the lower plenum bolts when i installed the aramid gasket. is this ok? i did torque them down to 100 inch lbs in the correct order.
i hope the bolts dont come loose and fly into my engine.
Old Oct 14, 2006 | 09:01 PM
Eazzy's Avatar
Eazzy
U should have, but the lowers should be torqued to 30 in lb lbs and then 60 and then 100--U be cool--But u should have, to cover ur butt.
hulkout
Apr 28, 2017 09:00 PM
_koubie_
Sep 20, 2015 06:34 PM
