Top Speed Y-pipe and Kinetix Hi-Flow Cats???
Old Dec 27, 2006 | 03:34 AM
Hot Cu's Avatar
Hot Cu
SlammednFlush
Question Anyone w/ Top Speed Y-pipe and/or Kinetix Hi-Flow Cats setup
Anyone get this Y-pipe? If so what kind of gains did you see? Does it make the exhaust sound a little louder?
I currently have the Helix 3" exhaust and need to upgrade the Y-pipe and the cats. I am thinking about the Top Speed Y-pipe and Kinetix Hi-Flow Cats. Does anyone has this setup?
Any sound clips or pics would be appreciated.
Thanks.
Old Dec 27, 2006 | 10:49 AM
Hot Cu's Avatar
Hot Cu
SlammednFlush
Bump. No one has this setup?
Old Dec 27, 2006 | 03:35 PM
godmans's Avatar
godmans
Thanks.
I am not sure about the CATS but the Y-power should help the air-flow of the exhaust system (sound increase is very minimial; some report taht there is a small resonator in the stock Y).
I would suggest try sth like a NISMO Y instead tho...
Old Apr 27, 2007 | 03:56 PM
hodahkwen's Avatar
hodahkwen
The Top Speed y-pipe is a complete 3 inch piece. It has a 3 inch inlet and 3 inch outlet. The Topspeed y-pipe will not match up well to the stock cats/aftermarket cats/test pipes because most of them are not 3 inches. This y-pipe is intended for Turbo applications. This is not a good system for a N/A car. You should look for a different y-pipe. Most of the others have a 2.5inch inlet which comes together in a 3 inch outlet. This would be a much better y-pipe for you.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
