5/16 motordyne spacer install
Old Jan 10, 2007 | 03:03 AM
JKC350z's Avatar
JKC350z
Default 5/16 motordyne spacer install
hey, Im about to install this in my car tomorrow.
Does anyone kno how long the install usually takes?
Also, are there any how-to's for the spacer install here? Ive searched but came up with nothing.
I know the kit comes with the instructions, but just wanted to see the install from someone else's point of view as well....dont want to screw anything up!
Thanks guys!
Old Jan 10, 2007 | 04:50 AM
The instructions are complete. Just recognize the difference between inch/pounds and foot/pounds.
Old Jan 10, 2007 | 04:58 AM
savvy's Avatar
savvy
inexperienced person you will probably be looking at like 1.5 - 2 hours
Old Jan 10, 2007 | 10:30 AM
mg350ZR's Avatar
mg350ZR
Originally Posted by JKC350z
... Also, are there any how-to's for the spacer install here? Ive searched but came up with nothing. ...
Here you go:
http://www.motordyneengineering.com/manual.pdf
...and another:
http://www.hypersprite.com/auto/tech-z-002/index.asp
...and one more:
http://www.superchargersonline.com/content.asp?id=191
Old Jan 10, 2007 | 12:43 PM
Heres a simple hint to keep the upper plenum out of your way while working:
Clip a small S-hook to the underside of the hood. Tie a cord about the upper plenum. Hook the cord to the S-hook.
Old Jan 10, 2007 | 02:00 PM
JKC350z's Avatar
JKC350z
thanks guys
Old Jan 10, 2007 | 02:12 PM
JKC350z's Avatar
JKC350z
hey....do i have to install the coolant control valve....i have the iso thermal version and im a litte confused with all the stuff they gave me...sorry this is the fitst time working on the 350z and I used to have a wrx...so everything is a little diffferent for me.
how do i actually install the iso thermal gasket and do I need to install the coolant control valve? thanks
mine came with alll these nuts and bolts like strut bar spacers and whatnot that i dont think I even need...please advise
Old Jan 10, 2007 | 03:12 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The instructions for the gasket should be included.
It will be VERY obvious where to put the gasket once you take off the old plenum etc.
As for the CCV, you don't really need to install it. It requires cutting a hose. So if you're unsure what to do, just don't install it. It won't make any HP.
Old Jan 10, 2007 | 03:40 PM
Roger V's Avatar
Roger V
Make sure you have torque wrench. If you don't rent one from Autozone or something, and make sure it is inch-pounds. The CCV is an easy install once the intake tube. Didn't notice anything from it but I think it will be useful during the hot California summers.
Old Jan 10, 2007 | 03:43 PM
JKC350z's Avatar
JKC350z
i got the iso thermal kit...and im not gonna install the gasket or ccv...too much work for really no gains...maybe ill see it or somethign
Old Jan 10, 2007 | 04:17 PM
z-u-later's Avatar
z-u-later
The CCV is a quick install and depending on where you live (warmer climate will benefit from it), it might be worth it. To install the CCV -- cut the hose, insert the valve ends on each hose, tighten the clamps, and you're good go. Let us know how things go after the install and the quick drive to feel the "butt" dyno.
Old Jan 10, 2007 | 04:33 PM
Mazinger Z's Avatar
Mazinger Z
Important: Don't drop any nuts! LOL I did it a few times...it's a biatch
Old Jan 10, 2007 | 06:56 PM
JKC350z's Avatar
JKC350z
i might install it we shall see...i live in stl, mo and we have not too hot of summers...maybe like 90's for real highs but prob nothing like cali or arizona
Old Jan 10, 2007 | 07:07 PM
Eazzy's Avatar
Eazzy
Instructions are good ---Only thing different thing I do is use that CRC spray sealer on the perimeter gaskets just to make sure I have a good seal
Old Jan 10, 2007 | 07:35 PM
JKC350z's Avatar
JKC350z
with the locktite liquid stuff....do u put it at the tip of the screws or on the threads?
Old Jan 10, 2007 | 10:23 PM
metal_gear350's Avatar
metal_gear350
dont worry its very easy just take your time and go step by step. I just did mine today and i was quite worried too but if you have basic knowledge you'll do fine. once you get started it all falls to place.
Old Jan 10, 2007 | 10:26 PM
JKC350z's Avatar
JKC350z
thanks for the input and encouragement...im handy with tools...just careful and want to get it done the right way...cuz i remember when i was new to cars i took apart some stuff on an old accord and lets just say....something got messed up lol...but now im just more knowledgable and know wut im doing
Old Jan 11, 2007 | 04:36 AM
z-u-later's Avatar
z-u-later
Yes, you definitely need to make sure you place all the items that you've removed away from the engine bay. You don't want to drop anything in your motor! Place a table near your car where you can layout all the parts. Just take your time and enjoy this DIY project. It's definitely a worthy mod.
Old Jan 11, 2007 | 07:28 AM
Eazzy's Avatar
Eazzy
Just a drop on the end of the thread
Old Feb 14, 2007 | 06:04 AM
Question
So how did the install work out?
