Rattling
Old Feb 26, 2007 | 11:13 AM
Cannysage's Avatar
Cannysage
Default Rattling
I went back to stock (my NA Z) and it runs and idles perfect. But there's a rattle somewhere. I will be double checking everything this weekend, but can anybody think of anything off hand?
Old Feb 26, 2007 | 11:17 AM
ANXIOUZ's Avatar
ANXIOUZ
Can you tell from where? My culprit was the center brake light. I had to wedge 2 pieces of foam between the plastic and rear glass. That solved it.
The only other noise came from my headunit. If I press in the console the noise stopped. Then it went away altogether....
Old Feb 26, 2007 | 12:02 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
my cup holder rattles sometimes.
my parking permit that hangs from my mirror rattles sometimes too.
is it interior or exterior?
Old Feb 26, 2007 | 12:19 PM
Cannysage's Avatar
Cannysage
man, I just read my own post and should've been more specific. I've installed my oem cats and oem exahust.. so it's somewhere within the exhaust system.. thanks.
Old Feb 26, 2007 | 12:21 PM
Sean's Avatar
Sean
loose heatshield on cats?
Old Feb 26, 2007 | 12:26 PM
ANXIOUZ's Avatar
ANXIOUZ
I had a rattle with my Borla hitting the rear stabilizer bar. Might take a look at that. If there is less than 1" or so of clearance when turned off, it might be hitting when it's vibrating at lower RPMs.
Old Feb 26, 2007 | 12:34 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
y-pipe upside down?
did you install the cat brace?
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
Lee3Z
Nov 1, 2002 01:39 PM
PrototypeStan
Oct 25, 2002 06:00 PM
