Take off plenum
I doubt if you will have a problem. Adding a spacer includes an additional gasket and longer bolts. That's about it. Hint: when you put the plenum together again, torque the bolts properly.
Search is your friend
https://my350z.com/forum/showthread....t=upper+plenum
https://my350z.com/forum/showthread....t=upper+plenum start with post#13
As per the spacer instruction from Motordyne:
6 bolts in center of plenum: 60 inch pounds
12 bolts on outer edge of plenum: 100 inch pounds
When I reinstalled my OEM plenum I went ahead and torqued everything to 61 inch lbs, using the tightening sequence provided to me from another source. I haven't noticed any leaks so far. What's your take on this?
allmycarsdie
May 13, 2016 04:38 PM
