which Exhaust is the best for NA
Old Sep 4, 2007 | 04:12 AM
Z Rated Z's Avatar
Z Rated Z
Default which Exhaust is the best for NA
ive searched and didnt find much info on this but i was wondering what exhausts were bad for NA Z's i read the one post about 3 inch TD being bad for NA,
I either want to get greddy Evo 2, BORLA, Tanabe Concept G, RSR,
which one of these is bests for NA, the EVO 2 is my number 1 choice so far and are any of these bad for NA
Some explain to me whats bad and whats not im a noob lol and i dont want to lose any HP or torque
Old Sep 4, 2007 | 04:18 AM
tienlo's Avatar
tienlo
They're all quite good. The distinguising factors you need to consider are:
Looks
Brand name
Dual vs Single
Value
Weight
Sound
There are no aftermarket exhausts which are considered Bad for NA but Good for FI. You're safe if you buy brand name like you described.
Custom exhausts - you're in unexplored territory and could lose torque/hp.
edit:
Actually, there is some interesting stuff i just read about back pressure / scavengine / free flowing characteristics in NA exhausts. for example in the <ahem> Volvo forum post 12 is interesting reading
http://forums.turbobricks.com/showthread.php?t=8394
futher edit:
my god they are a mature forum haha
Old Sep 4, 2007 | 04:34 AM
ZPirate's Avatar
ZPirate
Sport Z Magazine did a comparison test several years ago. You might try searching for that here on the forum or check out Nissan Sport's website to see if they have it archived there.
Personally I have a Borla dual exhaust. Nismo, Stillen and Injen also make exhuasts for the Z that have gotten good reviews.
Old Sep 4, 2007 | 05:10 AM
I recommend that you:
a. Set a budget.
b. Decide what configuration is best for you. Single. Dual. One or two mufflers.
c. Listen before buying.
Old Sep 4, 2007 | 05:13 AM
Z Rated Z's Avatar
Z Rated Z
my budgets around 1100 or under i want either one of the ones i listed up there probly evo2, if not evo2 then probably borla or tanabe concept g just wanna make sure all these are legit for na
Old Sep 4, 2007 | 05:22 AM
JrZkid's Avatar
JrZkid
I was in the same situation as you're in now a few months. I had pretty much the same budget and wanted the best results with my new exhaust. I decided to go with the RSR. It sounds great and looks great. It's also an easy bolt on. Before you decide which exhuast to buy i would check out the sound clips for them.
Old Sep 4, 2007 | 05:46 AM
kham25's Avatar
kham25
Just a quick question will you loose low end torque when changing to an aftermarket exhaust? I've been told that you gain high end power but your low end will suffer
Old Sep 4, 2007 | 06:44 AM
Exhaust mods (headers, test pipes, cat-back exhaust) will alter the horsepower and torque curves. Predicting the exact effects is a guess at best.
Old Sep 4, 2007 | 06:59 AM
stalarman@yahoo's Avatar
stalarman@yahoo
^ So in all realities this is what a "TUNE" will correct? Putting a ratio of the fuel and oxygen to make it perform back to normal and correct the imbalances through the power band??
Old Sep 4, 2007 | 07:24 AM
Correct.
A tuner with a dyno can tweak the ECU for better performance. That's why a session with a knowledgeable tuner will cost about $900.
Old Sep 4, 2007 | 08:08 AM
Ruthless18x's Avatar
Ruthless18x
noobs
Old Sep 4, 2007 | 08:27 AM
Doba's Avatar
Doba
Borla on sound alone
Old Sep 4, 2007 | 08:29 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Fast Intentions sounds very nice
Old Sep 4, 2007 | 08:45 AM
ZPirate's Avatar
ZPirate
The Borla does sound sweet. Even more so when you add headers.
Old Sep 4, 2007 | 08:52 AM
i8acobra's Avatar
i8acobra
If you're staying NA, get a single pipe exhaust like the Nismo or Borla single. Duals are absolutely unnecessary and add weight. I have the Borla TD because I'll eventually have some sort of FI or an LS2 swap.
Old Sep 4, 2007 | 09:24 AM
__jb's Avatar
__jb
Z + Rear Seat
I'm surprised no one has mentioned HKS here...
Old Sep 4, 2007 | 12:15 PM
tribal_visionz's Avatar
tribal_visionz
I'm eventually doing N/A, im pretty sure im goin single.
Old Sep 4, 2007 | 12:17 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I say get the Nismo, great part, and perfect fit. I had one along time ago and loved it.
Old Sep 4, 2007 | 12:21 PM
NA&CH's Avatar
NA&CH
Nismo sounds stock with a higher pitch. I love the way the nismo sounds. I will ethier do a single to be mad tyte jdm or the nismo.
Goodluck
Chris
Old Sep 4, 2007 | 05:16 PM
redkaz04's Avatar
redkaz04
HKS IMO!! Excellent quality, fit, and finish...worth every penny!
