Nismo midpipe ruined after one day... help needed
Old Oct 11, 2007 | 09:01 PM
Spiffyguitar's Avatar
Spiffyguitar
Originally Posted by kramykram
The problem is the nismo exhaust BLOWS.
Old Oct 12, 2007 | 11:42 AM
Spiffyguitar
Now an SES light. The fun continues! Haha.
Old Oct 12, 2007 | 11:33 PM
gsazabi's Avatar
gsazabi
You can try getting JIC Y-Pipe. It's super flexible and allows your TP to have more flexibility. It would be better if you can a TP with flange support(such as UTR)
Old Oct 13, 2007 | 04:46 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
? the NISMO Y pipe he already has with his exhaust (comes with it) has the same such flex sections
my comment on removing items was direct at kennyl5123
Old Oct 13, 2007 | 04:48 AM
Z1 Performance
Former Sponsor
no, the problem is the el cheapo made in god knows where test pipes most people try to attach to this, and other exhausts, "blows"\
get a good set of test pipes and you won't have a problem, ever
Old Oct 13, 2007 | 07:13 AM
gsazabi's Avatar
gsazabi
Yea but Nismo Y-Pipe blows. I cracked my HFC cuz of the Nismo Y-Pipe. After switching to JIC no problems. Much more flexible.
Old Oct 13, 2007 | 09:22 AM
Spiffyguitar
So... the JIC y-pipe fits the Nismo S-Tune exhaust?? if so I'll buy one, and switch over to a higher quality TP, or HFC. Can't wait to get this thing fixed!
Thanks everyone for the input and help so far.
Old Oct 13, 2007 | 10:06 AM
gsazabi's Avatar
gsazabi
JIC fits Nismo. In addition to being super flexible, it also allows better air flow. Nismo Y-Pipe is piece of crap anyway.
I would recommend UTR resonated TP with it. CAUTION: it'll be super loud though.
Old Oct 13, 2007 | 10:12 AM
Z1 Performance
Former Sponsor
A NISMO Y pipe is a Fujitstubo Y pipe - it's anything but a piece of crap....
again, the problem is the things you guys are bolting to your exhausts, and/or the way you are installing them, not the exhausts themselves.
I've sold countless NISMO exhausts to people - I've never had to replace a single component for anyone in nearly 4 years. The reason being simple? We only offer a handful of test pipes and only 1 brand of cat, because they are the only ones we've used to date that we feel comfortable and confident in.
Not that I am knocking the JIC Y pipe at all - it's a good piece for sure, as is the Tanabe. Hell the Ichiba one is every bit as good as both of them (probably comes from the same place) and it's even cheaper.
I'd love for someone to show me how one Y pipe "flows" better than another. I've used nearly every one on the market at this point - until you go with a very worked NA motor, or forced induction, no Y pipe is "better" that another from any of the major manufacturers.
Old Oct 13, 2007 | 10:31 AM
gsazabi's Avatar
gsazabi
Nismo = Fujitsubo that's true. I have issues with Nismo because it allows almost no flex, which caused many users' TP and HFC to crack.
I'm one of them and now I have no problems with JIC now. You're right about
matter being what being attached to the exhaust is important(i.e. I would never put something without support brace). I'm just trying to help OP get a setup they'll benefit him the most with extra safety.
JIC pipe is straighter than Nismo. However, the biggest advantage would be that it flexes much better to ease the burden on the TP/HFC stress points.
If there's a Y-Pipe is just as straight and is flexible as JIC and cheaper, that's great news; go right on ahead OP.
As for TP I would still recommend UTR.
Old Oct 13, 2007 | 10:34 AM
Z1 Performance
Former Sponsor
we'll agree to disagree then
Old Oct 13, 2007 | 11:09 AM
BADASSTT's Avatar
BADASSTT
If I get the Z-1 test pipes am I going to have to deal with the check engine light coming on all the time.Because if thats the case I will go with HFC's instead.Let me know.
Thanks
Old Oct 13, 2007 | 10:09 PM
Spiffyguitar
gsazabi JIC fits Nismo. In addition to being super flexible, it also allows better air flow.
Thanks for the advice! I am going to replace my y-pipe, and I'll probably use this as a replacement. As far as loud goes it's all good. This Z already has Nismo with TP's, and I use to drive a Camaro with a 40 series Flowmaster.
Z1 Performance we'll agree to disagree then
Well put.. thanks for the advice from both of you. I like forums like this where I can get several points of view, and in this case I'll be taking both of your advice.. I would like to buy my goodies from you to fix my current problem... I just want to make sure whatever I do it's gone for good. I haven't decided on what to replace my current TP's with. I sort of want to change to high flow cats, but a high quality set of TP's would work too I guess. I've debated on just slapping my stock cats on, but I don't want to loose the marginal gains I've made. What would you recommend for HFC's?
Old Oct 14, 2007 | 09:08 AM
Z1 Performance
Former Sponsor
Thanks
we don't offer any test pipes or cats for the 07 Z at this time, sorry
Old Oct 14, 2007 | 09:12 AM
Z1 Performance
Former Sponsor
The only high flow cats we will ever sell are those made by Ultimate Racing. I used these on my own since 2003, and they have performed admirably. We offer them in both ceramic and metal substrate, and details can be found on our site on each:
Metal: http://www.z1auto.com/prodmore.asp?m...t&prodid=2747\
Ceramic: http://www.z1auto.com/prodmore.asp?m...ust&prodid=580
Please note the newer versions of the UR cats (for the last several months) do not have the bracket anymore - precisely for the reasons I've outlined already. The factory cat has a bracket because of the weight of them. These Ultimate Racing ones weigh substantially less than stock, and as such, do not need any such bracketry. We've used these cats extensively with the NISMO and Fujitsubo exhausts, among others (Stillen, Borla, HKS) without incident.
For the Y pipe, I'd recommend the Tanabe one, or if on a tighter budget, the Ichiba one (we offer both)
Old Oct 15, 2007 | 12:46 AM
Spiffyguitar
Welp... after doing a little more reading (I'm tired so it wasn't much) I decided to order the JIC y-pipe to replace the Nismo. Of course I'm a man of my word, so the order was placed with Z1 Performance.
As far as replacement cats/tp's go I'm still scratching my head a bit. It seems like everywhere you go someone has had issues with Nismo conflicting with one combination or another. All input is welcome and obviously being put to use. Haha. All I know is that In less than 3 weeks I'll have spent something like 2 grand on my Nismo before I'm done with everything (and I don't even have headers!!).... If it's still giving my crap after this I'm going to scrap everything and just drive around with an open exhaust.
Old Oct 15, 2007 | 05:04 AM
Z1 Performance
Former Sponsor
Sorry to add insult to injury, but check your email - we no longer offer JIC products, and have been in process of deleting all their items from our site. The reason is due to their lack of after-sale support. We made the decision as a result to not offer their product line any longer.
For Y pipes, we offer the Fujitsubo, Ultimate Racing, Ichiba and Tanabe
Sorry for any inconvenience
Old Oct 15, 2007 | 08:56 AM
  #38
Spiffyguitar
Man... not my week I guess. I didn't see Fujitsubo, Ichiba, or Tanabe y-pipes on your site.
Old Oct 15, 2007 | 09:13 AM
  #39
Z1 Performance
Former Sponsor
Fujitsubo: http://www.z1auto.com/prodmore.asp?m...ust&prodid=307
Ichiba: http://www.z1auto.com/prodmore.asp?m...st&prodid=2837
Tanabe: http://www.z1auto.com/prodmore.asp?m...st&prodid=2836
Old Oct 15, 2007 | 09:33 AM
  #40
Spiffyguitar
My only concern with those y-pipes is that they're nearly identical to the design of the Nismo. Granted I'll be changing out my TP's, but it makes me a little uneasy.
