Kinetix V+ vs. Motordyne 5/16" vs. Motordyne 1/2"
Old Oct 13, 2007 | 11:11 AM
Originally Posted by ssnake86
This is the same plenium that looks all crazy with like 4 pipes going down on the right side?
No. That is the Kinetix SSV.
Old Oct 13, 2007 | 01:02 PM
terrasmak's Avatar
Originally Posted by pony_killer
save your money and just get the Motordyne 5/16 spacer and MREV 2...guaranteed that their both the best bang for your buck mods.
Actually MREV2 is useless for the non revup motor he has , so its acually a waste of money . The spacer and the kinetic plenum are close to the same price , bit do the same thing. I went plenum cause its plasic and wont heat soak like the factory alum upper
Old Oct 16, 2007 | 08:23 PM
PhiSig's Avatar
PhiSig
Wheel Whore
So the Kinetix V+ is made out of plastic?
Old Oct 16, 2007 | 09:12 PM
terrasmak's Avatar
polymer , if its good enought for guns and a lot of factory intakes , its good enough for the aftermarket.
Old Oct 21, 2007 | 06:38 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Spoken like somebody who doesnt know $hit. MANY people have cracked those with low boost levels, even though they claim it holds XX boost I owned an original rewelded Crawford plenum from about 4 years ago! It cracked on me recently at the welds from running 13+psi. I replaced it with a 1/2" MD spacer, works great, pulls harder from 6000rpm's+ the thing is big, and no leaks. I need to put washers on my hood though cuz it does rub enough that it marked the powder coating on the upper plenum. Pics
Old Oct 21, 2007 | 06:42 PM
bacalhau16's Avatar
bacalhau16
Seems as if there is a bit too much of that on this forum lately. We need more moderators to control all this misinformation.
Old Oct 21, 2007 | 11:12 PM
terrasmak's Avatar
F you b$tch , what part of what i said is wrong ????? Was the guy asking about FI stuff???? Would i recomend this intake for an FI motor, probably not. Drink bleach
Old Oct 22, 2007 | 10:56 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Its a POS-they have even cracked NA (I know aguy who's Kinetix cracked with bolt-ons!), so again please STFU and take your own advice. I post from EXPERIENCE not heresay...
Old Oct 22, 2007 | 11:07 AM
gothchick's Avatar
gothchick
My my... Have we not taken our meds today? ~ Lol!
Old Oct 22, 2007 | 12:47 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Cool it. Alberto attacked your weak statement with his experience, but he did not say anything bad about you.
You, in turn, attacked Alberto as a person, for disagreeing with him.
This is your only warning
Old Oct 22, 2007 | 03:36 PM
scmtkings4's Avatar
scmtkings4
so for a non rev-up Z, the 5/16' spacer is what is best? Also i heard about how the spacer will change the sound of your car? I have a nismo exhaust, is the spacer going to make a noticeable change in sound? ANd if it will, in what way will it change it? Deeper? Louder? The reason im asking is because i dont want the spacer to take away the sound of the NIsmo. but if it will make it louder in the low RPMs, im all for it
Old Oct 22, 2007 | 05:06 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Non revup-choose bewteen Crawford, or 5/16" to keep stb, 1/2" if you want MINIMAL gains over (5/16")it and lose the stb. Engine growl through intake wil be slightly deeper, nothing crazy.
Old Oct 22, 2007 | 05:27 PM
terrasmak's Avatar
And what part of him saying that i dont know sh$t is not saying anything bad about me????
Old Oct 22, 2007 | 05:32 PM
Nexx's Avatar
Nexx
to the OP, if you want a show look, get a polished plenum, it looks 100% better then the black plastic. get the 5/16th spacer with the iso thermal gasket and you are good for show and go.
Old Oct 22, 2007 | 06:58 PM
scmtkings4's Avatar
scmtkings4
ok so with the spacer the growl through the intake will be deeper. Is this sound change any noticeable when heard on the outside? In other words, would a friend standing on the outside notice that the sound is different?
Old Oct 22, 2007 | 07:09 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you don't know the difference between "you don't know ****" (attacking your knowledge) versus "f*** you b*tch" (attacking someone emotionally) then you're going to offend a lot of people in your life.
Old Oct 22, 2007 | 09:19 PM
terrasmak's Avatar
"polymer , if its good enought for guns and a lot of factory intakes , its good enough for the aftermarket." Look it up , look at how many companies use polymer for their intakes. Next look at Glock , Ruger etc etc , where is my knowledge faulty.
Yes Kinetic had problems with the first few designs , and the latest hasnt had any problems.
Old Oct 23, 2007 | 05:59 AM
  #38
Alberto's Avatar
Alberto
Cranky FI Owner
Do you seriously think its the same polymer that is used in guns? Thats like saying gas is gas, 87 octane or 116 octane its the same Just drop it, your wrong. I wouldnt recommend that plenum to anybody...
Old Oct 23, 2007 | 06:00 AM
  #39
Alberto's Avatar
Alberto
Cranky FI Owner
You are thinking way too into it. It is HARDLY to NOT noticable from outside the car. Your exhaust note isnt going to change to the point your describing above.
Old Oct 23, 2007 | 08:46 AM
  #40
taurran's Avatar
taurran
Just a side note - we recently dyno'd my built turbocharged car with a 5/16" plenum spacer. The thing was blowing out and leaking after about 12psi, so we took the spacer out. We gained an immediate 30+whp.
Not saying they aren't bad, but the stock plenum is great for boost unless someone like Cosworth can design one that's fully intended to make use of positive manifold pressure.
I'd never use the Kraknetix plastic plenum on a boosted car.
