APS Tallboy Plenum Install Question
Old Nov 5, 2007 | 02:19 PM
DMK's Avatar
DMK
Default APS Tallboy Plenum Install Question
http://www.airpowersystems.com/350z/plenum/bom.htm
Someone tell me why you need #11 on the parts list?
Do you really need to install those bolts?
Old Nov 5, 2007 | 02:51 PM
iyah's Avatar
iyah
Go ahead and say it, you dropped #11 somewhere in the engine bay. LOL
Old Nov 5, 2007 | 02:54 PM
DMK's Avatar
DMK
lol. I bought it used and those four bolts were missing. I am guessing that they are replacing some stock bolts in the same location.
Old Nov 5, 2007 | 03:12 PM
iyah's Avatar
iyah
Does anyone know if he'll have a vacuumed leak if he doesn't put those screws in? What you could do, hehe I dropped one when installing a kenetics is goto a auto parts store with the long screw that filled it and tell them you want a smaller one with the same threading.
Old Nov 5, 2007 | 07:32 PM
XenoJC's Avatar
XenoJC
if you look at your stock plenum and compare it to aps tallboy. you will find out why you need them four bolts. i'm sure you can order those through contacting aps or find the simular bolts at you local autoshops.
Old Nov 5, 2007 | 07:37 PM
XenoJC's Avatar
XenoJC
he will probably have a leak. Even if no leak, its better to have it anyway.
You can actually go to the dealer and but the stock bolts from the top and cut it short or bring that bolt to the auto shop and buy the same thread size with shorter length.
Old Nov 6, 2007 | 12:02 PM
VO...'s Avatar
VO...
Administrator
I'm curious as to what purpose the 4 bolts have. I've personally only installed a 5/16th spacer. Instead of having bolts in these locations, they had plastic spacers.
VO(likes to learn new things)
Old Nov 6, 2007 | 12:52 PM
kramykram's Avatar
kramykram
you will have vacuum leaks, the crawford comes with 4 bolts that go there also. beleive me they are there for a reason
bcoffee20
Nov 19, 2015 06:39 PM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
