Headers Install Pricing..
Old Dec 2, 2007 | 08:36 PM
Amiricanmade's Avatar
Amiricanmade
Default Headers Install Pricing..
How much should i pay?
Old Dec 2, 2007 | 08:38 PM
hwood's Avatar
hwood
$400-$600 takes a while
Old Dec 2, 2007 | 08:40 PM
Amiricanmade
holy mother of god! anyone wana do it for $200
Old Dec 2, 2007 | 08:51 PM
SuperBlack350z's Avatar
SuperBlack350z
for 200 umm no. If you know the work that is involved,i think you would gladly pay 400-600 for install.
Old Dec 2, 2007 | 09:30 PM
Amiricanmade
your sig is cute
Old Dec 2, 2007 | 09:33 PM
SuperBlack350z
Originally Posted by Amiricanmade
your sig is cute
thanks.
Old Dec 2, 2007 | 11:52 PM
AUtigers350z's Avatar
AUtigers350z
+1
Header install is a pain in the ***.
Old Dec 2, 2007 | 11:55 PM
TheBlackPearlZ's Avatar
TheBlackPearlZ
superblack i also love your sig...ever since you made it all sexy ive been wanting to hump your leg....(totally joking)
Old Dec 2, 2007 | 11:56 PM
SuperBlack350z
sure you are
Old Dec 3, 2007 | 01:56 AM
TheBlackPearlZ
sure you are
yeah your right...i really really really would like the oppurtunity to hump your leg
when i get back from the sandbox ill install them for you for 300...
Old Dec 3, 2007 | 05:03 AM
meaj82's Avatar
meaj82
I paid a little over $200
Old Dec 3, 2007 | 05:13 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
all depends which headers (some take alot longer than others) and who is doing it
Old Dec 3, 2007 | 06:41 AM
HondaKiller's Avatar
HondaKiller
Paid $350 for mine, took them 8 hours to do the install. I think it was around $45 an hour for labor. Not too bad because i was there for the removal of the stock heat sheilds and headers, and wow is all i got to say. My money was well spent, becuase i couldn't have dreamed of doing it on jack stands in my garage.
Old Dec 3, 2007 | 06:53 AM
track04's Avatar
track04
im doing it now, i have taken both stock manifolds off, and have the passenger side manifold on. i am 6 hours into it on jack stands.
i cant get the drivers side header in without removing the steering shaft, and i was not able to remove it as of last night.
i gave up when i noticed that my headers and test pipes didnt have studs built in, so i would have to use all new bolts to connect cat back to test pipes, and test pipes to headers. all stores were closed so i just stopped last night.
its very hard to access some bolts, and you hands will get cut up big time.
Old Dec 3, 2007 | 07:01 AM
gothchick's Avatar
gothchick
+1
That's reasonable.
Old Dec 3, 2007 | 07:10 AM
App6MT's Avatar
App6MT
I did mine for free.
Well a 12 pack of beer.
Old Dec 3, 2007 | 07:15 AM
gothchick's Avatar
gothchick
Try lossening the driver's side motor mount (17mm nut under the engine cross beam). Then use a crow bar to shift the engine slightly to the side. You'll need a friend to help. One person rocks the engine, the other slips the header in place.... It's a PITA~
Also, don't forget to heat wrap your fuel lines, power steering lines, AC line, and clutch line.
Old Dec 3, 2007 | 07:35 AM
track04's Avatar
track04
so you mean the steering column shaft stays in place and by rocking the engine there is enough room to get a header in there?
i can try that.
i actually used your tutorial to do it, good info, thanks
Old Dec 3, 2007 | 07:44 AM
gothchick's Avatar
gothchick
I wish I could take credit for that tutorial. Lol. That was just something I found on a different site and thought it could help our community....
I recently had my headers installed at Perf Factory, & we did the engine rocking trick to get the driver's side header in... I guess disconnecting the steering column wouldn't hurt either, but we didn't have too on mine.
Ohhh, I did take some advice recently and bought a 30" 3/8 extention to easily get to the bolts that mate up the header to the cat. Works like a charm.
Old Dec 3, 2007 | 09:03 AM
HondaKiller
releasing the rear motor mounts are necessary for most header installs. if you can release them the engine will tilt back enough to reach the top bolts. I had a turbo shop do mine and they said it was worse than a header swap on a mustang. Some people remove the steering shaft instead of tilting the motor. Whatever is easiest for you i guess.
