Relocating evap canister on Amuse exhaust
Old Dec 10, 2007 | 06:28 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by Tac-M
hi tony! could you possibly custom fab a few kits to help us out ? all it nees to be is a box with 3 holes ( that match the stock connections) some longer hoses and a mounting bracket. I know there will be very little demand, but for a custom, good quality part like that I would pay $$$.
thanks, ak.
I'll get back under the car and look into it.
I just may need one for the exhaust I am working on, but have been trying to avoid doing anything with the evap.
Old Dec 10, 2007 | 06:37 AM
Tac-M's Avatar
Tac-M
thank you tony, as long as it is a sealed canister, it works. the size really does not matter, my pvc can, is no larger than a can of coke.
so something like a generic oil catch can with modified connections will work very well.
Old Dec 10, 2007 | 08:00 PM
Hydrazine's Avatar
Hydrazine
If thats the case, why not just use a 3-way hose fitting?
Old Dec 10, 2007 | 08:05 PM
jonnylaw's Avatar
jonnylaw
hmmm. I'm really hoping that my tech is able to install everything correctly by removing the heat shield, shaving down a corner of the canister, wiggle it around a bit, and heat wrap the canister and lines. From what I gather it would be a tight fit, but entirely possible and less hassle then having to fab up a new evap canister and find a proper place and bracket to mount it.
But if anyone can do it I know Tony can! Good luk Tac with finding a permanent solution. I'll let you guys know how my install turns out.
Old Dec 10, 2007 | 08:50 PM
Hydrazine's Avatar
Hydrazine
Thanks for the props Jonny. If it can be done this easily, I'll find a way to refine it enough to make it look like a stock part. Shouldn't be hard.
Maybe a simple 3-way brass fitting with with specific accomodations at each side? ...It sure would make the whole evap box fitment problem go away quite nicely.
I know a few people in my area with the same exhaust system and they have the same issues. Even with thermal tape, the corner of the box gets melted.
On a different subject...
When you assemble your exhaust on the car, take a good look at the flanges on each side of the b-pipe. Are the b-pipe flanges square and parallel to the mating flanges of the y-pipe and muffler section?
Old Dec 11, 2007 | 06:13 AM
Tac-M's Avatar
Tac-M
thank you ! ! !
i would think that all amuse owners and some greddy owners would like to get this kit. I know I am
Old Dec 11, 2007 | 08:32 AM
jonnylaw's Avatar
jonnylaw
Tony, u the man, u know that. You made the most cost effective hp/$ mod for the revups. You continue to develop parts for the VQ community. I think I speak for all of us, that your are an invaluable resource!
Regarding the assembling of the exhaust, I requested to my tech that he photo the process of the installation of the exhaust, so hopefully you're question can be answered when I receive those photo's. I wish I could have been their for their install, but I had an interview today (that didn't go so well btw )
Thanks for your time and effort Tony!
Old Dec 11, 2007 | 08:49 AM
Hydrazine's Avatar
Hydrazine
Good Luck on the job hunt!
Sometimes the interviews that don't seem to go well are the ones that actually do.
It happend to me when I interviewed at Boeing. I thought I bombed it, but I got hired.
Old Dec 12, 2007 | 07:22 PM
jonnylaw's Avatar
jonnylaw
quick couple of revs not under load:
http://home.comcast.net/~jofficer1/a...use%20blip.wav
will try to do a proper flyby sometime soon
Some installed pic's (tech will forward me some pics of the install process and I will post them when they are received:
My tech was able to sucesfully relocate the evap canister a good 3/4 inch away from the amuse pipe--some heat wrap around the lines and such--there is a nice clearance I think--he did a good job!
Old Dec 13, 2007 | 07:15 AM
THE TECH's Avatar
THE TECH
Looks good!! Just needs the Ti y-pipe and it would be perfect!
Old Dec 13, 2007 | 07:19 AM
gothchick's Avatar
gothchick
Nismo Diff cover looks sweet.
Old Dec 13, 2007 | 07:26 AM
singh's Avatar
singh
_______________
Do teh ricer fly-by!
Old Dec 14, 2007 | 03:53 PM
na_350z's Avatar
na_350z
I'm just purchased a Evo'2 exhaust and noticed that it wont be coming with an EVAP relocation kit. I've read on here that there's no need to relocate the EVAP just wrap it with heat wrap, shave off the corner that touches the exhaust and wrap all lines. Is that correct? And has anyone gone this route. I have no clue on how to relocate the EVAP nor what to use to relocate it. I rather not move anything but I want to make sure that wrapping the EVAP and lines is safe!!!
Old Dec 15, 2007 | 11:17 AM
Tac-M's Avatar
Tac-M
with evo-2 relocation is a must ! or it won't fit. as far as i know, greddy ships them with a kit. so unless you got it used or something you should have it.
Old Dec 15, 2007 | 11:22 AM
na_350z's Avatar
na_350z
Thanks bro... that's exactly what I wanted to know. So I guess I have to figure out a way to relocate the EVAP without the braket. I purchased the exhaust used so it wont be coming with the braket. Now to figure out a way to relocate it. I'm thinking now that I should just have purchased the exhaust new.
Old Dec 17, 2007 | 08:57 PM
jonnylaw's Avatar
jonnylaw
After a couple of days with the Amuse--I reallly like it! with the Tanabe it's really deep and quite mellow until wot, when it screams and has a titan exotic type sound.
Sorry for the delay on the drive-by all, freezing temps and 8+ inches of snow has created a problem--but as soon as the weather gets a little better I'll do a super ricer fly-by and post the video!
Old Dec 18, 2007 | 07:25 PM
jonnylaw's Avatar
jonnylaw
Some more pic's of the install process:
Old Dec 18, 2007 | 07:27 PM
  #38
terrorist22's Avatar
terrorist22
Contact Corner3 Garage in Irvine. I have an Amuse exhaust and all they did was remove some more plates on the outboard side of the car, and it allowed the EVAP canister to move a couple of more inches.
Old Dec 21, 2007 | 05:01 PM
  #39
jonnylaw's Avatar
jonnylaw
btw all, I am working with my tech on a custom aluminum heat shield to fit over the evac box, and then possibly a custom air deflector... Will post pics when completed.
Old Dec 22, 2007 | 09:18 PM
  #40
jonnylaw's Avatar
jonnylaw
a few sound clips of in cabin:
http://home.comcast.net/~jofficer1/cabin/cabin1.wav
http://home.comcast.net/~jofficer1/cabin/cabin2.wav
http://home.comcast.net/~jofficer1/cabin/cabin3.wav
