Borla Hiss Fix SOlution Found Maybe!!
Old Jan 19, 2008 | 05:29 AM
DraGonAlchemist's Avatar
DraGonAlchemist
Default Borla Hiss Fix SOlution Found Maybe!!
I'm doing an alignment on a g35 with rims installing camber kits n what not. .and i noticed he has a Borla TD like me but when pulling it in and revving it up a tad i hear that there was no hiss like mine. .so then i looked underneath after getting it on the lift. .and noticed where the H pipe was he had it clamped tightly and had the big hose clamps pulling the H pipe together. .now why didn't i think of that. . so after im done with his adjustments. .im going to throw up my Z and see if that fixes my hiss. .and i'll repost to let you know. .
BTW. .guy has a huge Bend in the inner lip of front right rim!! DAMN!
Old Jan 19, 2008 | 05:37 AM
iceagetlc's Avatar
iceagetlc
I tried everything to salvage my Borla. This post gives me horrible flashbacks.
Old Jan 19, 2008 | 05:49 AM
DraGonAlchemist
haha sorry!
Old Jan 19, 2008 | 05:58 AM
HondaKiller's Avatar
HondaKiller
interesting.
Old Jan 19, 2008 | 06:12 AM
SniperHunter's Avatar
SniperHunter
I haven't heard any hissing noises out of my Borla. :|
Old Jan 19, 2008 | 06:21 AM
DraGonAlchemist
check my video and listen for the hiss after i rev it and let it calm down. ..
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i266.photobucket.com/player.swf?file=http://vid266.photobucket.com/albums/ii244/DragonAIchemist/Nissan%20350%20Z/MOV00121.flv">
BTW. .everything is NICE and tight. .i check and have rechecked anytime i get a chance!. .i think it's my exhaust gases mixing in the H pipe. .or could be cause i have header's and test pipes who knows. ..
Old Jan 19, 2008 | 06:23 AM
SuperBlack350z's Avatar
SuperBlack350z
you do know almost all exhaust with test pipes do that right?
Old Jan 19, 2008 | 06:25 AM
SniperHunter
Dude, that's rasp coming from your test pipes. Not your exhaust.
Edit: Dammit, beaten by SuperBlack. Word of advice: get resonated test pipes and a Magnaflow x-pipe to replace the Borla H-pipe. Eliminates all sound issues.
Old Jan 19, 2008 | 06:28 AM
DraGonAlchemist
when under the car tho i hear it at the H pipe not at the Test pipes. .but you could be right. .if thats all it is i dont mind it. .
Old Jan 19, 2008 | 06:34 AM
SniperHunter
I'm guessing you installed the Borla after you installed your test pipes?
Old Jan 19, 2008 | 06:37 AM
DraGonAlchemist
no i did it all at once. .xcept for the header's i did after. .but you kno. .your probably right on the tp's making the noise cause this guy doesn't have tp's he's just got cat back Borla. .so i think your right. .although i remember other's with the borla always complaining about that hiss. .and it was cars with out tp's. . so im kinda lost but w/e. .as long as the pipes aren't leaking out any where im fine with the hissing. .
Old Jan 19, 2008 | 07:09 AM
05Z33's Avatar
05Z33
The hiss does come from the H pipe. I heard it myself when my car was on the lift with res-testpipes. With cats on no hiss at all. I was once told that the reason for the hiss is the gauge of the borla pipe is thin compared to other exhausts. Maybe thats why adding the x-pipe seems to eliminate that sound, but we'll soon see when I install it on my exhaust.
Old Jan 19, 2008 | 07:10 AM
DraGonAlchemist
ok cool ..,if it does eliminate that sound write back or PM me the outcome
thanx!
Old Jan 19, 2008 | 07:13 AM
GA_VQ's Avatar
GA_VQ
IT IS NOT THE TEST PIPES! I don't have test pipes and my Borla does the same exact thing.
Old Jan 19, 2008 | 07:20 AM
350Zenophile's Avatar
350Zenophile
Post before and after pics...
Old Jan 19, 2008 | 07:25 AM
DraGonAlchemist
yeah i already kno it' s not the test pipes. .but i dont argue anymore. .heh. .i know for a fact it's the exhaust gases mixing within the h pipe smashing into each other and creating that hiss effect from the force of passing through one another.. .the reason this G doesn't have the hiss. .is because he blocked the center pipe of the H pipe. .he just explained it to me. .i asked him why didn't he just do away with the H pipe and use separate pipes. .he said it had better support this way!
Although the Z's need that Equalization between sides of engine through exhaust. .if i were to do away with my H pipe and use Individual pipes rather then an X as well ..i'm thinking the exhaust gases get mixed in the rear muffler anyway. .correct?
Old Jan 19, 2008 | 07:35 AM
SniperHunter
Well that's just damn weird. My Borla does absolutely nothing like that. I even have clips of it.
Old Jan 19, 2008 | 07:38 AM
DraGonAlchemist
hmm well not everythings made perfectly the same. .maybe you got lucky with yours haha. .let see clips of it tho .
Old Jan 19, 2008 | 07:58 AM
350Zenophile
That's exactly what mine sounds like with hfc and headers...following the other thread with the magnaflow x-pipe. Seems like the best solution to me. I also recall some old posts saying the welding the h-pipe fixes it as well...dunno how or why...I think the theory was that it is leaky w/all those clamps.
Old Jan 19, 2008 | 10:41 AM
DraGonAlchemist
but thats just it. .mine has no leaks i check and re check and i have someone inside revving it up and i feel around a listen for leaks and there is NONE!!!
