o2 sensor or Cats?
Old Mar 23, 2008 | 03:18 PM
bswanny's Avatar
bswanny
Default o2 sensor or Cats?
I tried to search but I'm not exacty sure which answer would pertain to my problem so I'll just ask for help. I installed high flow cats over 3 months ago and now I get the dreaded "service engine soon " light. I used an OBD2 scanner and found out the code related to the cats sensor in bank one. Is there I trick I'm not aware of to prevent this from happening (non fouler)? Also do I need to replace this sensor to prevent my engine from running lean? I'm not even going to pretend like I know what I'm talking about so any help would be greatly appreciated. Thank you ahead of time for any help.
Old Mar 23, 2008 | 03:22 PM
cdoxp800's Avatar
cdoxp800
1. What HFC's you running. Some are know to cause this, and you may need foulers.
2. you may have a Bad o2 sensor or lose connection.
I installed Berk Cats and have no CEL.
Old Mar 23, 2008 | 03:38 PM
seekndestroy19's Avatar
seekndestroy19
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/194001-test-pipe-ses-non-fouler-fix-pics.html
Old Mar 23, 2008 | 03:39 PM
seekndestroy19
also can your scan tool read a/f? if it can check it. I know sometimes you can reset the ecu so it can re-learn fuel trim and adjust a/f. I did that with my test pipes and it worked. No more CEL
Old Mar 23, 2008 | 05:42 PM
Its very unusual for high-flow catalytic converters to give you a SES light, but it is possible. I suspect that the problem is a failed oxygen sensor.
Old Mar 23, 2008 | 06:35 PM
BlackMamba2448's Avatar
BlackMamba2448
how many o2 bungs do you have? 2?
put the o2 sensors in the extended one (the one where the sensors don't actually stick out into the piping)
i had the same problem and that fixed it for me
Old Mar 23, 2008 | 07:26 PM
Escobar's Avatar
Escobar
if that doesnt help you probably have a faulty o2 sensor, they are fairly fragile.
Old Mar 24, 2008 | 03:36 AM
bswanny's Avatar
bswanny
I have the UTR high flow cats and as far as I know there is only one o2 sensor on the cats. Also on the scanner I had I cleared the code but should I still replace the o2 sensor? Thanks again for all the help.
Old Mar 24, 2008 | 06:53 AM
seekndestroy19
if the problem persists then the light will come back on
Old Mar 24, 2008 | 09:23 AM
bswanny's Avatar
bswanny
does anyone know the part number for this sensor? thanks again
Old Mar 24, 2008 | 10:21 AM
seekndestroy19
OEM Part#226A0AM601. Thats what i got from alldata here at school. O2 sensor bank 1(right side)
Old Mar 25, 2008 | 08:40 PM
How many miles are on the catalytic converter? I doubt that the cat has failed internally.
Old Mar 28, 2008 | 09:11 AM
bswanny's Avatar
bswanny
the cats have about Five thousand miles on them but know I'm also recieving errors saying all the cats sensors (4 of them ) are below the thresehold? Does this mean I have to replace all four now? Thank you
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
