Kinteix V+ and MREV2???
Old Jun 28, 2008 | 12:43 AM
Nismo350Z_00's Avatar
Nismo350Z_00
Exclamation Kinteix V+ and MREV2???
Is it even possible to use the two together??? And would it even benifit me at al??? I have the Rev-Up motor.
Old Jun 28, 2008 | 04:04 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Absolutely, you can use them together with good results.
The upper plenums and spacers, by themselves, have no effect on a stock revup lower plenum, but once you hook up the MREV2 it completely changes everything.
For you, the MREV2 will make no less than 15+ HP and 18+ TQ. And it often does quite a bit more.
If you can, install the MREV2 while at your local dyno shop to quantify the gains.
Old Jun 28, 2008 | 12:07 PM
Nismo350Z_00
ok kool> i just put on the invidia Test pipes. now all i need is the Mrev2 and a damn Y-Pipe and i will have all breather and exhaust mods, lol. YAAAY lol
Old Jun 29, 2008 | 07:04 AM
JCstart's Avatar
JCstart
and what about the mrev2 with a FI application like a vortech ?
Old Jun 29, 2008 | 07:54 AM
Hydrazine's Avatar
Hydrazine
I havn't pre/post dyno tested the MREV2 when FI. If you install it, try to get a pre/post dyno of it.
