test pipes
Old Jul 18, 2008 | 12:54 PM
t-350z's Avatar
t-350z
Default test pipes
I Have the invidia n-1 exhaust and Im in the market for test pipes. I heard topspeed/rs-r/ invidia dont make rasp with non- res tp because the way the exhaust is set up. Is this true?
Now i need to know what tp are good for the z? quality is the key. I have the 07 model.
Old Jul 18, 2008 | 01:02 PM
OldDirty Z33's Avatar
OldDirty Z33
I would go with the berk or crossworth HFC
Old Jul 18, 2008 | 02:09 PM
t-350z's Avatar
t-350z
berk has a good set of tp? I know the threads have come up about berk hfc cracking. Could this be the same problem for the TP as well?
Old Jul 18, 2008 | 03:25 PM
TreeZ's Avatar
TreeZ
I love my Labree resonated test pipes! Quality is top notch. Don't know how they would sound on with the Invidia though.
Old Jul 19, 2008 | 09:06 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
If you have the Invidia N-1 exhaust, then it must be pretty damn loud. Adding in test pipes into the mix (with or without appropriately sized y-pipe), will make it even louder. That's all personal preference, though.
As far as the rasp goes, all test pipes will you give you that. It doesn't matter if it's resonated or not. The severity depends on the exhaust/test pipe combination.
Also, don't waste your money on all these expensive exhausts if you drag race (or even like to be aggressive at times). I've broken the welds on all of my previous test pipes (excluding the current one, but I know I will eventually) from all my aggressive launches and shifts at the drag strip.
And make sure you buy the appropriate test pipes for your Z. 07-08 (HR engines) don't have a wide selection at the moment, if I recall correctly. In addition, the HR Z's are having a problem with the CEL coming on, even with the non-foulers. Not only is that annoying and isn't all that great as the ECU will be pulling a bit of timing, you'll also have a hard time passing inspection.
Old Jul 20, 2008 | 01:22 PM
t-350z's Avatar
t-350z
lol i figure it would make it louder thanks. What you mean pulling a bit of my timing?. http://videos.streetfire.net/video/3...aust_89106.htm . no rasp in that i only need to know what type of tp he has : (
Old Jul 20, 2008 | 04:17 PM
Legr19's Avatar
Legr19
megan racing. they come with resonators + flex pipes so they're pretty hard to crack. ive had mine for about a month with no problems and they're also pretty cheap in price.
Old Jul 20, 2008 | 06:06 PM
350zDex's Avatar
350zDex
I Just Got Helix Tp's I Have A Topspeed Exhaust And It Got 3 Times Louder Very Little Rasp Around 3 To 4k Rpm After That Niceeee Tone But I Might Change Them And Get Hfc's Tp's A Little To Loud For Me!!
Old Jul 20, 2008 | 06:18 PM
A.H's Avatar
A.H
Go with fast intentions resonated test pipes. Have only heard good thigns about them and have never had a probelm with mine. Plus they sound awsome.
Old Jul 20, 2008 | 08:06 PM
3hree5ive0ero
Retired Admin
We have a "learning" ECU where the ECU adjusts various aspects of the car depending on its input signals from various sensors. When our cars throw a SES/CEL code, related to exhaust components for example, it can adjust the adjust a few aspects of the engine to now run as aggressively as it could to prevent damage. As far as the ECU knows, when you throw a code from having test pipes, it thinks your cats have gone bad. As a result, it will also pull timing to run less aggressively, which also means less emissions (our cars were also designed with emissions in mind as are other cars).
Again, I'd like to stress my previous post to you. Read and re-read it and keep it in mind.
Let me know if you have more questions and I'll try to answer them to the best of my abilities/knowledge.
Old Jul 20, 2008 | 10:07 PM
t-350z's Avatar
t-350z
i dont think meagan and helix mapes pipes for the hr engines also ill look up the fast intentions pipes they were also in the category for purchase.
so 350 your saying my car wont run to its full pontenial cause its not letting it run as agressivly as possible?
Old Jul 20, 2008 | 11:34 PM
3hree5ive0ero
Retired Admin
I didn't say that.
All I'm saying is:
-read up on how to avoid or get rid of the CEL light for your Z (huge thread here)
-buy whatever test pipes you want (they'll all eventually crack/break with aggressive driving)
Old Jul 21, 2008 | 01:59 AM
Blk03G35's Avatar
Blk03G35
I ran ebay test pipes for 20K miles with no problems on my G. Just make sure to get ones that allow for connection to the chassis.
Old Jul 21, 2008 | 12:20 PM
t-350z's Avatar
t-350z
o ok i see. hmm really 03g35? Do you know which companies that make the test pipes for the Hr engines that do connect to the chassis? If so ill probably buy those if they look good. All pretty much the same which im finding out.
Old Jul 21, 2008 | 01:36 PM
t-350z's Avatar
t-350z
what about AAM tp for 07? anyone had experience from them? im pretty set on them . need last minute opinions
Old Jul 21, 2008 | 01:40 PM
A.H's Avatar
A.H
^^^Also a great choice. Have heard nothing but good reviews and quality seems to be very good with them. I personally ahve no experince with them though
Old Jul 22, 2008 | 12:22 AM
Blk03G35's Avatar
Blk03G35
X3
Old Jul 24, 2008 | 04:08 PM
t-350z's Avatar
t-350z
well i just order the aam tp for the 07 . ill let you guys know how it turns out. Thanks for the advice.
Old Aug 4, 2008 | 03:26 PM
t-350z's Avatar
t-350z
well now i need a y pipe but i wanna get the AAM but the AAM one says its a 2.5 then out to a 3 inch now wouldnt that fit over and i will have problems?
Old Aug 4, 2008 | 06:50 PM
3hree5ive0ero
Retired Admin
Going from a smaller piping size to a bigger one doesn't affect anything. It's when you do the opposite, you end up with turbulence inside your pipes, which could also result in loss of power.
From your sig, it says you have test pipes and Invidia exhaust. Buying any aftermarket y-pipe that isn't stock-sized, will be beneficial to your set up. It'll be louder, though.
