I need help with test pipes and exhaust?
Old Oct 18, 2008 | 11:04 PM
IvoryNismo#1393's Avatar
IvoryNismo#1393
Exclamation I need help with test pipes and exhaust?
Ok, so i have a 2008 Nismo 350z #1393, and i am going to buy Titek stainless test pipes for my nismo cat-back exhaust that came stock with the nismo. but, what i am worried about, is will it fit? i have been looking at the nismo exhausts on the web and none of them look like the ones on my car. so if any one has any information, help, or tips on install etc. then please respond thank you.
-IvoryNismo#1393
Old Oct 19, 2008 | 03:54 AM
matix101vz's Avatar
matix101vz
post pics of what ur exhaust looks like ... crawl under there and snap some shots .. then you will get some help
Old Oct 19, 2008 | 06:17 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Yes, it will fit. Make sure it's for 2007 +. But why Test pipe? why not HFCs? no smell gas, no CEL lights. TP < HFC.
NismoZ is stock exhaust with bigger tips and has nismo 'logo'
( Hope owner doesn't mine using his picture)
Nismo S-tune, more sharp tips, it is 3" y-pipe back.
-JLee
Old Oct 19, 2008 | 08:14 AM
singh's Avatar
singh
_______________
If I recall, Titek does not make test pipes for the 07+ year model Z's.
Only Berk, Fast Intentions, and AAM. And yes these will fit your stock exhaust and all other aftermarket exhausts.
Old Oct 19, 2008 | 07:02 PM
IvoryNismo#1393
ok, thanks for the response, on the titek test pipes that i am looking at it says 04 and up but out of all the test pipes mentioned Berk, Fast Intentions, and AAM what do you think is the best, and as for the CEL light, i know how to fix that problem for about 14 bucks
Old Oct 19, 2008 | 07:29 PM
singh's Avatar
singh
_______________
No you don't know how to fix the problem. The non-fouler trick works on DE engines (03-06 year models). You can put a non-fouler on the HR's but it will eventually show a CEL after you drive a certain amount of miles. It might behoove you to add brillo padding into the non-fouler to lengthen the interval of when your CEL shows.
I recommend get a test pipe that comes with support brackets. This will provide support to the test pipes and will help prevent cracking.
With that said I believe Berk is the only test pipes that utilizes support brackets. However, they are also the only ones to utilize 2.25" inner diameter piping, while Fast Intentions and AAM use 2.5" piping. It is up to you to decide whether you want 2.25" or 2.5" test pipes.
Old Oct 19, 2008 | 07:50 PM
IvoryNismo#1393
so you think i should just go with the hfc rather than the test pipes? the test pipes that are 2.5 inches will be louder and generate more hp right?
Old Oct 19, 2008 | 08:02 PM
singh's Avatar
singh
_______________
No. To be honest, I don't know which test pipes generate more hp. Even if one does produce more power than the other, it will be a marginal difference.
One thing you should take into consideration: What cat-back exhaust will you be using? If you are using your stock one, then think about it. Your stock piping diameter is somewhere in the neighborhood of 2.25". If you throw on a 2.5" test pipe mated to your 2.25" stock cat-back, you will have a flow transition from big diameter (2.5") >>>> small diameter (2.25"). That will disrupt your flow and hence it can make your exhaust sound like crap.
Let's say you got the Berk HFCs or test pipes, both which utilize 2.25" piping. Then you will have a perfectly mated exhaust system; 2.25" cat/test pipes >>> 2.25" stock exhaust. I believe this is the best setup. Others may disagree and I could care less.
BTW, I recommend get Berk's HFCs. They will not trigger a CEL and have proven gains.
Old Oct 19, 2008 | 08:33 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
i advise u to search. Yes this is a forum where u can ask questions but u should always see if u can solve the problem before u ask answer and become the problem
IvoryNismo#1393
ok thanks, i think i am going to go with the fast intentions test pipes 2.25", i like how they sound over aam and berk tp's
thanks for the help and recomendations
Old Oct 19, 2008 | 09:26 PM
hellsoldiers08's Avatar
hellsoldiers08
o i just got fast intentions resonated test pipes and with in twelve hours i got the light that always stays on . Im currently trying to think of a way to fix the problem. My friend told me of some device that makes your car think that o2 sense is working correctly. Right now i totally forgot the name of it,sorry if i couldnt remember.
Old Oct 19, 2008 | 09:33 PM
singh's Avatar
singh
_______________
ok thanks, i think i am going to go with the fast intentions test pipes 2.5", i like how they sound over aam and berk tp's
Fixed.
Old Oct 19, 2008 | 09:39 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
100% i agree.
Old Oct 20, 2008 | 05:23 AM
Get_Zwole's Avatar
Get_Zwole
mines been on for 1.5 years just check the code every once in a while and make sure your not throwing another you'll be fine.
Old Oct 20, 2008 | 07:38 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Non-foulers? But i don't know if it works for HR model.
Old Oct 20, 2008 | 11:09 AM
hellsoldiers08
ya, that what i think about doing but i dont want to pay money for something that is not a 100% going to work. :L
Old Oct 20, 2008 | 11:17 AM
t-350z's Avatar
t-350z
get the aam test pipes. mines only come on once. cleared it and it hasnt came back sense. TEST PIPES >>>> HFC
Old Oct 20, 2008 | 06:37 PM
singh's Avatar
singh
_______________
AAM test pipes come with a built-in non-fouler, positioning the O2 sensor much further away from the exhaust stream. Notice the J-type bung in this picture:
Old Oct 20, 2008 | 07:50 PM
2004Black350z
Exhaust Whore
i wish the test pipes for the DE was like that
Old Oct 21, 2008 | 08:19 PM
matix101vz's Avatar
matix101vz
i installed non foulers on my test pipes and i still got a CEL, why is that
