Kentix SSV or Aps upper plenum+Mrev2
Old Dec 30, 2008 | 11:33 AM
McLovin350Z's Avatar
McLovin350Z
Default Kentix SSV or Aps upper plenum+Mrev2
Ok Z drivers
Facts
Im a 350Z TT driver - APS setup
I've been around this forum and others and heard different opinions
I still have not seen any facts(other than dealer claims) that either one is better
At this point i have the APS upper plenum on my car and i haven't had any problems and even had decent gains when i wasnt FI
I believe i could see some gains if i get the MREV2 to add to the fun
Would i be better off getting the Kentix SSV seeing how it deletes the use of a plenum setup?
Has anyone done any dyno studys........personal feelings of this are wanted as well!!!!!!
Old Dec 30, 2008 | 06:33 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
year of your Z may help
Old Dec 30, 2008 | 06:55 PM
McLovin350Z
Old Dec 30, 2008 | 07:08 PM
cdoxp800's Avatar
cdoxp800
Originally Posted by McLovin350Z
2003
Don't bother with the MREV2. This Mod is more for the Rev-up's
Old Dec 30, 2008 | 07:25 PM
Changvi's Avatar
Changvi
Stick with 5/16 spacer and call it a day. It yields most gains, and its comparable to SSV, if not better for NA.
Old Dec 30, 2008 | 10:24 PM
McLovin350Z
So changvi
you are saying add the 5/16 spacer to the APS upper plenum (i already the APS) and that setup should pretty much be perfect?
Old Dec 30, 2008 | 10:25 PM
McLovin350Z
cdoxp800
Ok i hear ur opinion on the MRev
any opinion on the SSV?
Old Dec 30, 2008 | 10:41 PM
cdoxp800's Avatar
cdoxp800
cdoxp800
Price/Value. Go with the 5/16 spacer for N/a. The gains or not that different over the SSV for a N/a setup
If going FI 5/16 spacer or SSV. The SSV seems to show a little better gain in FI setup. But price wise I would still take the 5/16th space.
There are alot of talented people on this broad. I am sure if you did around on the search, you may find some dynos comparing the 5/16 to the SSV.
Old Dec 31, 2008 | 04:19 AM
McLovin350Z
i think you are a bit confused with my question
First im no longer concern with N/A setups because i am FI
Second i already have the APS upper plenum
I am thinking of building on to the APS upper plenum or getting the SSV
I understand you said the MREV wont help seeing how im not a rev-up
So in different words my big question is??????
So using as a combination you are saying use the APS upper plenum with a 5/16 spacer
over
the SSV?
Old Dec 31, 2008 | 06:36 AM
Changvi's Avatar
Changvi
So changvi
No, if you already have APS plenum, just stick with that because that is all you need. SSV is no better than APS when FI.
Old Dec 31, 2008 | 09:16 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Stick with the APS.
There have been quite a few individuals, moderators and dyno shops on this board that dynod the SSV for both NA and FI.
The general consensus is that the SSV loses "area under the curve" in the majority of cases.
You should be able to find the reviews with a search. Many of the reviews were in the 2006 time frame though so you will have to dig deep.
Old Jan 2, 2009 | 05:08 AM
McLovin350Z
thanks for the info
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
bcoffee20
Nov 19, 2015 06:39 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
