got bored made ram air kit
Old Jan 23, 2009 | 07:20 PM
beetlejuice's Avatar
beetlejuice
Originally Posted by gothchick
On the track there's no such thing as too much heat wrapping. Wait, who has never been on a track before.... Lol~
Zip ties on heat wrap is mo betta.
Old Jan 24, 2009 | 02:52 AM
Z04's Avatar
Z04
there is when it is used in places that it is not needed at all. and please do not make assumptions you know nothing about. thank you
Old Jan 24, 2009 | 04:46 AM
Ziggyrama's Avatar
Ziggyrama
I'm curious to see this 'ram air' intake.
BTW, there's really no such thing as 'ram air' intake on street cars. You don't go fast enough to pressurize the air to make any difference. Oh, and the longer you make the tubing, the more of a natural restriction you will produce. Your experiment, just considering the scientific side, will not make much of a difference. Believe it or not, the stock intake past the TB is pretty efficient. It has very few bends, it's relatively short, it produces good, laminar flow and most importantly, it draws fairly cool air from the front of the car. If you put a well flowing filter in it, you'll be hard pressed to make it better.
Because someone already has explained this very well, I'll redirect you to the below post here which really drives the point across why ram air is a myth.:
http://forums.corvetteforum.com/c5-t...tml?forum_id=1
I can give you a brief summary, ram air intakes are good on things that go very fast, like airplanes (300mph+). At speeds around 80mph, the gain of pressure from 'ram air' is less then 1%, Lol. Further more, it is important to understand intake resonance and why air boxes are good and design specifically for each car. Shade tree mechanics will swear by their ad-hoc creations but I usually side on the side of science confirmed by real world experiments. In reality, a lot of work and design goes into intakes. More often than not, most experiments like yours that lack correct instruments to measure the right variables (I assume you don't have a flow bench and other things to measure/characterize the flow) end up coming up short. Good luck and keep us posted on your results.
Old Jan 24, 2009 | 08:10 AM
beetlejuice
I read a few years ago that some guy had a ram air transam (WS6?).
The guy had installed a boost gauge in preparation for a supercharger install. He took the car out on the road (still NA) and at high speeds, the car made 1 or 2 psi from the factory ram air scoops.
I'm not trying to refute your explanation, just adding some more info.
Old Jan 24, 2009 | 08:47 AM
Dave B's Avatar
Dave B
I do agree with you on most everything posted especially about OEM airboxes, but I disagree about the effectiveness of ram air systems on cars. Ram air systems have been used and are effective on numerous street cars and motorcycles. F1 cars and other race cars employee similar systems. The G/Z OEM intakes are essentially ram air systems and do create a few extra HP (~2hp) at speeds over 60mph. The position of the intake snorkel in a high pressure area is all it takes. High pressure areas on cars are right at the nose (usually near the grill area) and at the base of the windshield. The real advantage of these systems is greatly improved throttle response.
Now as for owners designing their own ram air system, chances are it will be a failure. Pulling air in from near the bottom of the car is not going work. Additionally, if you take away the relatively air tight seal of the OEM airbox and air tract, you completely ruin the pressurization effect of the OEM design. Simply running a piece of pipe near an open filter WILL NOT result in a ram air effect.
Old Jan 24, 2009 | 08:51 AM
davidmcc's Avatar
davidmcc
Originally Posted by Z04
or overkill use of exhaust wrap. wait, where have i seen that before......
I was thinking the same thing
Old Jan 26, 2009 | 05:04 AM
gothchick's Avatar
gothchick
You need to do the same then. Thanks.
Old Jan 26, 2009 | 05:20 AM
Z04's Avatar
Z04
not sure where you are going with that, but oh well
Old Jan 26, 2009 | 05:44 AM
cracka350z's Avatar
cracka350z
bbq
/thread
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
