Borla owners: Do you think the H-pipe is restrictive?
Old Sep 9, 2003 | 03:40 PM
MY350Z.COM's Avatar
Default Borla owners: Do you think the H-pipe is restrictive?
The H-pipe looks funny to me. Looks like it could have been better designed. Has anyone tried to get a custom piece made to replace the H-pipe? Like maybe a X-pipe like Stillen. The Stillen is making more torque and I think it is partly due to the X-pipe.
Let me know what you think.
Thanks,
Victor
Old Sep 9, 2003 | 07:51 PM
2003z's Avatar
2003z
I dont think it is. It is not meant to flow air through in the exhaust stream, just to equalize the pressure between the two sides.
Old Sep 9, 2003 | 10:30 PM
Gsedan35's Avatar
Gsedan35
Default Re: Borla owners: Do you think the H-pipe is restrictive?
Thanks,
Victor
I fully believe that the stillen's X-pipe is the reason it has the power and torque gains that it does, especially when we make note that stillen used 2.5" pipe diameter, which is awfully large for what is serving half of 3.5 liters of displacement and the borla uses a more senseable 2.25" diameter.
I found this explanation of what H-pipes do and what X-pipe's do
"H Pipe:
An H pipe helps equalize the exhaust pressures between the two banks of tubing as the hot gases and sound waves travel down the tubing. This, in effect, relieves the exhaust pressures as they travel through the H tubing, generally creating an increase in torque. This will also give an added sound reduction when the sound waves combine inside the H tubing.
X Pipe:
An X pipe will actually help to scavenge exhaust pulses from one bank as the opposite exhaust pulse passes through the X, thus creating a vacuum effect at the valve, resulting in a cleaner burn in the cylinder. This generally equals added torque and, like the H pipe, a reduction in sound as the sound waves combine in the X pipe.
Old Sep 10, 2003 | 04:24 AM
MY350Z.COM's Avatar
Thanks guys!
Old Sep 10, 2003 | 06:32 AM
ChrisMCagle's Avatar
ChrisMCagle
Default Remove it?
Hmmm.. based on the definitions that Gcoupe35 gave both the H and X pipes reduce sound. I am wondering what the result would be if the H and/or X pipe was not used and straight pipes back to the muffler were used instead? Would the sound increase? Would it gain/lose hp and torque? Hmmmmmmmm.....
-Chrismcagle
sales@czp
Sep 23, 2019 03:30 PM
z33z_nutz
Sep 23, 2015 07:22 PM
