problem with hks exhaust
Old Mar 16, 2009 | 09:19 AM
fabcas311's Avatar
fabcas311
Default problem with hks exhaust
just bought a used HKS exhaust..but the seller didnt include gaskets/bolts
now i purchased some gaskets/bolts from autozone installed it on my 08 nismo................and
wow the sound is horrible/different....i had 06 before with hks....but
the sound is really different it has rasp and ricey!not the deep/throaty and amazing at wot!
do the gaskets played a major part on this one????
where can i get hks exhaust gaskets???
thanks
Old Mar 16, 2009 | 09:26 AM
fabcas311's Avatar
fabcas311
will this one fit?
http://www.directtuning.com/store/pc...54-GREDDY.aspx
Old Mar 16, 2009 | 09:41 AM
DJShan209's Avatar
DJShan209
are you sure its not an XO2?
Old Mar 16, 2009 | 04:42 PM
fabcas311's Avatar
fabcas311
nah..............its not bro.anyone?
Old Mar 16, 2009 | 04:57 PM
Sergio8A's Avatar
Sergio8A
does it sound like a single fart cannon(Agency Power maybe)
Old Mar 16, 2009 | 05:11 PM
fabcas311's Avatar
fabcas311
not really a fart cannon.....lol........but i can hear rasp.
again.
will gaskets affect the sound of the exhaust???
Old Mar 16, 2009 | 05:44 PM
scmtkings4's Avatar
scmtkings4
^^^i kinda doubt that the gaskets will affect the sound
unless you have an exhaust leak because of the gaskets? then maybe the sound will be different
Old Mar 16, 2009 | 06:58 PM
Sergio8A's Avatar
Sergio8A
yeah try aligning the gaskets right and make sure it doesnt stick in where the exhaust flow passes..
if you can post some sound clips that would help a little more
Old Mar 16, 2009 | 07:31 PM
costilla's Avatar
costilla
The gaskets will not affect the sound, but bro, I thought you were buying a new one I hope you didnt get scamed. I heard that at one time some hks exhaust were not built correctly. They had welds or something inside the pipes because the owner was experincing almost the same problems, but that is what I heard. Maybe this thursday, I will be able to hear it.
Old Mar 16, 2009 | 09:05 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
I'm pretty sure, rasp is nothing to do with gaskets/bolts.
You can use any metalic gaskets with HKS long as it is same size.
Old Mar 16, 2009 | 09:09 PM
Escobar's Avatar
Escobar
Are you running test pipes?
Old Mar 16, 2009 | 09:22 PM
red_magic2000's Avatar
red_magic2000
Greetings to my people here in the valley..But if the exhaust sounds nasty, then it is not the XO2, I have the CX Lighting on my 08 Z and it sounds great. Really helped performance also, acceleration improved instantly..YOu might try looking on ebay for the gaskets..I know I came across some when I was ordering my cheap imitation exhaust Which gaskets are you needing? I know I reused the stock gaskets on the cat. pipes.
Old Mar 16, 2009 | 10:26 PM
Phreakdout's Avatar
Phreakdout
That's the key question. I was an exhaust design engineer for 16 years and I can tell a lot from a good YouTube clip. Any chance of recording it?
As stated before, the gaskets (unless there is a major leak) would not affect the acoustics.
Is there any kind of whistle noise? Whistling is usually untrimmed pieces of pipe sticking up in a weld joint and forming a V shape. The exhaust flows through it and produces a whistle noise.
High frequency noise is usually removed by using resonators with stainless steel wool / mesh over fiberglass roving wool or basalt. Occasionally, a resonator is made where the operator forgets to inject the glasswool. The empty resonator can will produce a horrible tone. Tap on the resonator cannister. You can tell if it's empty or loaded by the sound.
I'm not a big fan of the gimmicky HKS tuning chamber design in their muffler. The diameter of the tuning tube that branches before the rear muffler is too large to be correctly calculated. In this case, they are simply adding muffler volume and bling. I'd wager that if the tuning cans were removed, the acoustics would be barely affected.
If it's low - deep sounding exhaust you seek, focus on removing high frequency. (Try replacing the resonators with ones that are a little longer and larger in diameter.)
Old Mar 16, 2009 | 10:40 PM
Sergio8A's Avatar
Sergio8A
Damn, i learned something new....thanx for the info
Old Mar 17, 2009 | 09:27 AM
fabcas311's Avatar
fabcas311
no tp..stock
Old Mar 17, 2009 | 09:30 AM
fabcas311's Avatar
fabcas311
the exhaust looks good,no cracks,dings or anything...got a good deal so its hard to pass on a used one.ill take my car today in a muffler shop hope they can see the prob.
Old Mar 17, 2009 | 09:33 AM
fabcas311's Avatar
fabcas311
thanks for the info
Old Mar 17, 2009 | 09:35 AM
Escobar's Avatar
Escobar
Originally Posted by fabcas311
no tp..stock
wow, you have stock cats and are experiencing rasp? thats hard to believe. I have berk's hfc and the hks pi-power and have no rasp at all. If you want help make a video and we can listen, thats about all I can say you can do.
Old Mar 17, 2009 | 09:37 AM
fabcas311's Avatar
fabcas311
yea thats what im thinking too....coz on my old 06 the hks sounds perfect.but this one sounds like an A$$..ill try to post some vids.
Old Mar 17, 2009 | 11:22 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Replace resonator or put x pipe. I do remember 'gotchick' did.
