Help with my 350z...chokes up!!!!!!!
Old Mar 26, 2009 | 08:57 AM
nemesis323's Avatar
nemesis323
Default Help with my 350z...chokes up!!!!!!!
Hey i need help with a problem that started yesterday...i was goin home from work and i usually smash on the on ramp to freeway and yesterday when i did it my car would start chokin up like at 4000rpm i didnt think much of it..on the freeway i shifted down and smashed and again it started chokin up, rpm keep goin up but no response to car...like 2 weeks ago i put a pro charger i was think maybe i was suckin up 2 much air since i also have a spacer..so i went back to stock intake today but it keeps doin this problem..funny thing is no check engine light nothin so i dont know what it is...anyone have had this happened?? Any suggestions would help...thank you
Old Mar 26, 2009 | 10:19 AM
s31t8n8's Avatar
s31t8n8
check the spacer, you might have a leak
Old Mar 26, 2009 | 10:58 AM
VO...'s Avatar
VO...
Administrator
Did you install you MAF sensor housing backwards?
Old Mar 26, 2009 | 11:11 AM
nemesis323's Avatar
nemesis323
i check for leaks on my spacer and theres none...I installed the MAF sensor correctly...everythin was good after i installed the intake, my car was runnin normal for like 2 weeks...this just started happening yesterday....
Old Mar 26, 2009 | 11:12 AM
nemesis323's Avatar
nemesis323
if my MAF was bad my check engine light would go ON right???
Old Mar 31, 2009 | 10:07 AM
0jiggy0's Avatar
0jiggy0
Right. If the RPM is going up and the car isnt moving it sounds like the clutch is slipping. you said you just put on a procharger, maybe its too much for the stock clutch to handle.
Old Apr 2, 2009 | 09:34 AM
nemesis323's Avatar
nemesis323
thanks for all the help guys....i still havent found the problem...i was thinkin maybe my fuel pump went bad and im not gettin enough fuel goin through????
