How long to wait before starting car after sealing exhaust with High Temp Red RTV?
Old May 21, 2009 | 05:49 AM
KS0385's Avatar
KS0385
Default How long to wait before starting car after sealing exhaust with High Temp Red RTV?
If I start it too soon, will it just blow out all the gasket material?
Old May 21, 2009 | 06:06 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Yes.
If you really want the best results, let it fully cure to the RTV specs.
Old May 21, 2009 | 06:07 AM
halfass872's Avatar
halfass872
My guess is it's gonna just blow out reguardless. RTV and hot exhaust aren't supposed to go together. High temp means it can take the heat of being on your engine, NOT the tempratures found on your exhaust.
Old May 21, 2009 | 06:32 AM
Allshow's Avatar
Allshow
normally you dont use it on exhaust. it does work to stop a leak for a quick fix.
Old May 21, 2009 | 06:49 AM
Hydrazine's Avatar
Hydrazine
Its not meant to get as hot as the exhaust gasses but it can work.
The exhaust tubing and flanges don't get nearly as hot as the exhaust gas is and this is how it is able to work.
Yes, I was very surprised in the beginning when I first saw it in use, but it does work.
I also found that you need to let it fully cure if you want it to last.
Old May 21, 2009 | 08:23 AM
Seb-Specialty-Z's Avatar
Seb-Specialty-Z
It will hold up if you use the right type of silicone. I recommend the copper Permatex for use on exhaust flanges.
Old May 21, 2009 | 09:59 AM
halfass872's Avatar
halfass872
The big question here is, why do you need this in the first place?? I've never had an exhaust leak.
Old May 21, 2009 | 10:09 AM
DMK's Avatar
DMK
I think you should use the Copper stuff on exhaust parts.
Old May 21, 2009 | 03:55 PM
NIZZMO's Avatar
NIZZMO
+1
Try tightning all your bolts down a little bit at a time till you have them
all tight then get them tourqed down to spec's.
Old May 21, 2009 | 04:02 PM
KS0385's Avatar
KS0385
Originally Posted by NIZZMO
+1
Fast Intentions Test Pipes don't use a gasket at that area. They just specify to use the Red RTV.
Old May 22, 2009 | 02:19 AM
halfass872's Avatar
halfass872
Make a gasket then!! That's gonna last way longer then RTV.
Old May 22, 2009 | 03:15 AM
0jiggy0's Avatar
0jiggy0
Is this up top where the header and TP meet? Maybe order the copper gasket from berk that they supply. If the RTV doesnt work of course.
Old May 22, 2009 | 04:27 AM
NIZZMO's Avatar
NIZZMO
Im not going to dispute Fast Intentions install directions, but I personally would rather make a set of gaskets. I had to do this with my Berk's at the Y pipe no leaks here. GL
Old May 22, 2009 | 04:34 AM
350 Rookie's Avatar
350 Rookie
Ive used the orange nissan gasket maker or my turbonetics turbo between the turbo and downpipe. Ive even used it on the uppipe. NO leaks whatsoever.
Old Jun 6, 2009 | 01:15 PM
thekinn's Avatar
thekinn
Search works. I had to resort to this due to leaks at the Cat-to-Y pipe. Though I didn't plan that well.. I need food, and can't drive the car (cure-time=24 hours). Time to dig in the cupboards.
..hoping to be leak free
smithmt3
Sep 11, 2015 08:25 PM
