what does a header do?
Old Jul 20, 2009 | 12:59 PM
skillkiller21's Avatar
skillkiller21
Default what does a header do?
i have an intake and i heard a header is good to get to gain more hp. Is this true and how much do they usually run for?
Old Jul 20, 2009 | 01:02 PM
dozzer1b's Avatar
dozzer1b
did u guys hear Michael Jackson died???
Old Jul 20, 2009 | 01:04 PM
quiksilverx181's Avatar
quiksilverx181
I will respond before someone comes and bashes you to search google (which is what you should have done).
A header is the part of the exhaust that is connected to your engine and leads down to the piping and out the back through the mufflers.
Bigger pipe = less of a choke point = more power. In a lot of states, like California, it is illegal to change to a non-CARB approved header, or any header that deletes o2 sensors and cats. It makes the car louder usually, but its usually worth the gain in performance in most cars.
Old Jul 20, 2009 | 01:09 PM
Spork's Avatar
Spork
A header allows more airflow to flow into the engine, translating into higher end pull along without losing bottom end. In other words, maximum horsepowers.
Old Jul 20, 2009 | 01:12 PM
PerfZ's Avatar
PerfZ
Um, a header(s) is installed on the exhaust side, not the intake side. Allows more airflow OUT of the engine, not into it. Or am I missing something in your reply?
Old Jul 20, 2009 | 01:15 PM
0jiggy0's Avatar
0jiggy0
If more air is exiting then what do you think is happening on the intake soide?
Old Jul 20, 2009 | 01:25 PM
Spork's Avatar
Spork
Yes, the header is installed on the exhaust side, but in return allows more higher intake air to be coming into the intake system, freeing up more powers. The stock headers are restricting very much and cannot free up with all this hidden power.
More airs flow into the intake side, allowing more power. Also header, keep the intake system cooler, allowing air coming in to be cooler to the touch. Very effectves.
Old Jul 20, 2009 | 01:32 PM
Kwame's Avatar
Kwame
http://auto.howstuffworks.com/question172.htm
Old Jul 20, 2009 | 01:39 PM
Entaille's Avatar
Entaille
I figured that sarcasm would go right over peoples heads lol
anyways - header gains on the Z are very minimal and the labor to install them is pretty intensive. not really worth while. could take 4-8 hrs to install headers for the Z. not typical for most cars.
if your z is 03-06, a plenum spacer will net you good bang for the buck. for any year z, test pipes and high flow cats are often the best value/performance purchase.
B Esquire
Sep 24, 2015 07:52 AM
z33z_nutz
Sep 23, 2015 07:22 PM
EnjukuRacing
Sep 9, 2015 06:42 AM
