any problems with nismo headers??
Old Oct 9, 2003 | 09:26 AM
drew703's Avatar
drew703
Default any problems with nismo headers??
I tried a couple of searches and went through a LOT of threads, but found mostly good things about nismo headers. I guess my main question is there any big issues or things to watch out for if i get headers? Not necesarily nismo specifically, but just any kind of problems related to having aftermarket headers installed?
thanks
Old Oct 9, 2003 | 03:22 PM
alex30327's Avatar
alex30327
No problems with mine except for a rough idle for a few days. The only thing that sucks about headers is that they are a pain in the Assss to install. Took me around 15 hours with the jack stands.
Old Oct 10, 2003 | 08:32 AM
stx's Avatar
stx
I haven't had problems with mine either. I did have a problem installing the driver side header though. On stud #1 I couldn't remove the wrench once I tightened the nut. I definitely didn't want to cut the stud to remove the wrench. So I had to fabricate a "special" wrench. Once I made the wrench I was able to tighten the nut and remove the wrench.
Old Oct 10, 2003 | 02:55 PM
drew703's Avatar
drew703
thanks for info
Old Oct 10, 2003 | 05:50 PM
can350z's Avatar
can350z
Default No problems....
You won't be disappointed, combined with high flow cats and full exhaust your car will make great power....and sound...
On a side note I finally gave up with my Stillen exhaust banging on the cross member and making clamp adjustments... Amazing what a little tig welding can accomplish.. problem solved..
R
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
