Exhaust rattle quick fix
Old Dec 9, 2010 | 06:14 PM
Shawz1102's Avatar
Shawz1102
Default Exhaust rattle quick fix
Hi guys, i searched and davidv recommended heat wrap to fix the exhaust rattle, but that is kind of too expensive for me.
I was wondering if there's any reliable alternatives for fixing exhaust rattle? Basically, there's 2 rattles that i know of.
1st one is the midpipe hitting the X brace, so i have to fit something in between.
2nd is the heat shield hitting my art pipes. the space between the two is so little that only a thin sheet of paper can fit unlike the clearance between the midpipe and x brace.
I was thinking about a rubber grommet in between the midpip and x brace, and wire it around the mid pipe... what do you guys think?
as for the test pipe rattle, i have no clue...
please help
Old Dec 9, 2010 | 07:28 PM
A-Town-Z's Avatar
A-Town-Z
Depending on what type of rubber you use, it may or may not melt. I know they make some pretty high temp rubber so that's a possibility. As for the wire, if that itself isn't adhered to the item in which you want to stop rattling, it will rattle at certain rpm's. I had wire holding my exhaust on my winter beater and that rattles ALOT. But you can try what ever you want. It's your car.
Old Dec 9, 2010 | 07:33 PM
Waiz's Avatar
Waiz
Heat wrap isn't that expensive, stop being a cheapskate and get with the program
Old Dec 9, 2010 | 07:55 PM
Zlucky1's Avatar
Zlucky1
Where is your rattle coming from?
If it is the mid section of your undercarriage it should be the heat shield or brace.
I would recommend you take off your brace. I really see no purpose for it. Take the bolts and tighten them down so your heat shield wont rattle mayb. Good Luck
Old Dec 10, 2010 | 03:31 AM
Old Dec 10, 2010 | 08:13 AM
Shawz1102's Avatar
Shawz1102
its coming from midpipe hitting the black brace like i mentioned. i dont want to remove the brace as its a big piece and is there for rigidity.
the other location is the driver side test pipes hitting the heat shield. it's literally a few milimeters away from the heat shield.
if i use heat wrap, are they self adhesive? how would i attach it to the pipes? is there some sort of heat tape that can withstand high temperature? i also heard about clamps... like these?
Old Dec 10, 2010 | 10:45 AM
A-Town-Z's Avatar
A-Town-Z
Originally Posted by davidv
^werd
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
