exhaust help
Old Jan 22, 2011 | 03:47 PM
wyatt51's Avatar
wyatt51
Default exhaust help
I have been searching and searching on this fourm and read everything posted about rattle, i have also done everything people have said to do to elemate rattle...but i still have rattle.
I removed the heat sheilds, checked all the bolts time after time to make sure there tight, nothing is rubbing or hitting anything, everything is lined up correctly, and everything is like it suppose it be.
The exhaust is true duel ark grip, motordyne test pipes. 07 HR
The rattle is coming from the front of the car, ( y pipe and test pipe )
when the revs come down between 3000 to 2000 the rattle starts and stops at 2000 and below and also at wot.
I have no idea what to do at this point. any ideas on what it is or anything that will help thanks.
Old Jan 22, 2011 | 04:13 PM
POWUH's Avatar
POWUH
had a similiar problem with my aam and injen exhaust , the problem was that the right side y pipe was hitting the m brace.The test pipes were not long enough to clear it. You will need to put the car in a lift and go underneath it to see where its hitting. I ended up taking it to the shop and the guy gave me two options. Either weld two , 3 inch pipes to make it longer or hammer the y pipe with a hammer. I ended up doing the hammer cause it was cheaper and I wanted to get it over with. Of course my y pipe is now dent but no more rattle , It did not change the sound of the exhaust at all. Hope this helps
Old Jan 22, 2011 | 04:14 PM
NissanZ03's Avatar
NissanZ03
are they unresonated test pipes?
Old Jan 22, 2011 | 04:59 PM
wyatt51's Avatar
wyatt51
When sitting in my car it does sound like its coming from the right side, Im going to try what you said
Old Jan 22, 2011 | 05:28 PM
terrasmak's Avatar
As mentioned above, check the M brace , its behind you but sounds like its coming from the front
Old Jan 22, 2011 | 06:04 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
found the problem. Never buy an expensive knock off
Old Jan 22, 2011 | 08:24 PM
NissanZ03's Avatar
NissanZ03
+1 I paid about $200 more for a used authentic one lol
Old Jan 22, 2011 | 10:29 PM
kramykram's Avatar
kramykram
wyatt where are you @ in mississippi?
Old Jan 22, 2011 | 10:40 PM
wyatt51's Avatar
wyatt51
Not sure what you mean ?
My exhaust is junk? Thats why I have this problem?
Old Jan 23, 2011 | 06:10 AM
NissanZ03's Avatar
NissanZ03
I'm not trying to say anything bad about it don't get me wrong, but the exhaust that you bought is a replica of an HKS exhaust. It might not even be causing the rattle or anything. The only thing is that you can buy basically the same replica exhaust for around $300 shipped on ebay and if I'm not wrong, the Ark one is almost double that
Old Jan 28, 2011 | 07:10 PM
POWUH's Avatar
POWUH
yes that's exactly where the sound use to come from. .
Old Jan 29, 2011 | 10:16 AM
wyatt51's Avatar
wyatt51
I found the problem. the rattle is coming form the xpipe.
I also talked to the ark rep and i sent him a video clip of what was going on and he explained that if your not running stock cats you will have a rattle. so basically if you plan on going with hfc or test pipes you will be getting a rattle, and ill be the first to say the rattle is unbearable to listen to.
Old Jan 29, 2011 | 08:21 PM
2004Black350z
Exhaust Whore
thats a BS excuse. ARK needs to step and and replace that sh1tty exhaust
Old Jan 29, 2011 | 08:45 PM
wyatt51's Avatar
wyatt51
yeah tell me bout it. Im switching to motordyne
Old Jan 29, 2011 | 08:54 PM
SuperBlack350z's Avatar
SuperBlack350z
i had the same problem. put the car on the lift. sounded like the rattle came from the test pipes/y pipe. found out it was a crack in the test pipe.
Old Jan 30, 2011 | 01:26 PM
wyatt51's Avatar
wyatt51
Just wondering where was the crack located on the test pipe.
Old Jan 30, 2011 | 05:59 PM
ap2_S2Kyle's Avatar
ap2_S2Kyle
maybe a resonated test pipe or hfc wouldnt have the problem?
Old Jan 31, 2011 | 04:10 AM
wyatt51's Avatar
wyatt51
No no no dont even think that. I have tried everything in the book and still had rattle and I also talked to people who has this exhaust and everyone said they had rattle when they took there cats off. If your not running stock cats, you will have rattle
Old Jan 31, 2011 | 09:35 AM
ap2_S2Kyle's Avatar
ap2_S2Kyle
taht really sucks..i was actually considering ordering one..ive been looking at the invidia gemini now it looks and sounds great and its true dual..i have searched on here..anyone who actually owns it have any input? how do u like it
Old Feb 1, 2011 | 04:46 PM
wyatt51's Avatar
wyatt51
<iframe title="YouTube video player" class="youtube-player" type="text/html" width="480" height="390" src="http://www.youtube.com/embed/u0kTd5-xRLc" frameborder="0" allowFullScreen></iframe>
this is with motordyne tp and this video is under the xpipe
