correct placement for 02 wideband sensor?
Old May 23, 2011 | 01:11 PM
Road Warrior's Avatar
Road Warrior
Default correct placement for 02 wideband sensor?
why would the wideband sensor be in front of the catalytic converter as in this picture?
all of the other aftermarket cats that i have seen the wideband sensor is located after the cat. in this case, the sensor is located right next to the 02 sensor.
Old May 23, 2011 | 04:11 PM
str8dum1's Avatar
str8dum1
behind the cat would not give you a proper reading for a wideband. Behind the cat is ok for a narrowband
Old May 23, 2011 | 05:31 PM
Road Warrior
here are some hfc from the same manufacturer for the 370
which setup would be better, the wb sensor in front or behind the cat for na application using utec?
tx
Depravity
Oct 1, 2015 04:49 PM
