Nismo CAI - Splash Shield
Old Aug 12, 2011 | 12:10 PM
irvrioa's Avatar
irvrioa
Default Nismo CAI - Splash Shield
I purchased a Nismo CAI, and I just have one worry. When I install the intake there is a spot damaged on my shield, and I don't want any water to be splashed into the filter and somehow cause a hydrolock.
I did some search on the forums, but they say only large amounts of water will cause an engine lock. I also don't have the bottom engine shield. I'm just trying to be safe
Should I worry about it?
It doesn't rain to much over here, but we do get occasional snow during winter.
Old Aug 12, 2011 | 12:47 PM
Waiz's Avatar
Waiz
Get a new fender lining before installing the filter, you are going to have to purchase a new filter every month otherwise from the damage you will cause.
Old Aug 12, 2011 | 04:15 PM
Bmurray350z's Avatar
Bmurray350z
I have had my cold air intake for over 5 months and haven't had a undershield on my car, and it's been fine.
Old Aug 12, 2011 | 04:38 PM
saywat?'s Avatar
saywat?
i wouldnt expose the filter to that much open dirt/debris.
Old Aug 12, 2011 | 04:40 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Old Aug 12, 2011 | 04:46 PM
saywat?'s Avatar
saywat?
^nismo cai comes with that so OP would already have that
Old Aug 12, 2011 | 04:53 PM
AdvanZ33's Avatar
AdvanZ33
Then hydrolock shouldn't be much of a concern.
Old Sep 12, 2011 | 10:16 PM
irvrioa's Avatar
irvrioa
Update: I've had the CAI installed now for about 3 weeks.
I turned the filter so that it faces more toward the bumper and less toward the hole. I have problems with sharp right turns, where it will scrape the shield because the intake pushes against it. but luckily its always at low speeds.
I may have installed it improperly, but I'll try to fix it tomorrow.
I already ordered my new guard, so I don't have to worry about constantly cleaning the filter.
Over all, great sound, the same as when I had a pop charger.
I did have to do the ECU and Idle Re-learn.
The idle is still a bit jumpy, but doesn't affect throttle response.
Old Sep 13, 2011 | 05:00 PM
saywat?'s Avatar
saywat?
^how are u able to turn the filter? the lower part of the cai only attaches one way. only thing u can adjust is how close the piping lays against the frame.
Old Oct 11, 2011 | 07:26 AM
irvrioa's Avatar
irvrioa
Well yea, it was the filter and pipe, that I turned together. Not to sure how to explain, but I got it to fit right
Old Oct 11, 2011 | 03:01 PM
TheDangerZone's Avatar
TheDangerZone
cut a section of screen and zip tie it to the liner... get some Flex seal...
http://www.youtube.com/watch?v=vwU8JObQMXc
I'm kidding btw, buy a new liner.
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
