Plenum Without Tune?
Old Jan 13, 2012 | 01:36 PM
  #41
khalafrommy17's Avatar
khalafrommy17
not idling rough at all.. but form a cold start the car dies or the rpm's jump down and then goes back to normal idle might think to take out the spacer,,, but i think even if i do the car will still do the same
checked if there is a leak (don't think there is)
retightened bolts
did an ecu and a TB reset
any suggestions?
i left the old plenum gasket in there, but i made sure that there was no bends in it and should still be sealed properly.
HEEEELLLPPP
Old Jan 13, 2012 | 06:52 PM
  #42
DarkZ03's Avatar
DarkZ03
Take out the gasket, the motordyne spacer seals by itself.
Old Jan 16, 2012 | 10:30 AM
  #43
VO...'s Avatar
VO...
Administrator
+1.
I had a leak towards the rear passenger side of the gasket after initial install...
Old Mar 29, 2015 | 04:09 PM
  #44
Z33Garage's Avatar
Z33Garage
I have :
Momentum performance cai
SRS catback exhaust
5/16 plenum spacer
Berk test pipes with curved O2 extensions
I will start saving for a tune. Hopefully it won't lean out too badly...
Old Mar 29, 2015 | 08:28 PM
  #45
DarkZ03's Avatar
DarkZ03
Should be fine for a while, I have intake, spacer, modded lower plenum, and a cat-back. Been running like that for a while without any issues.
Old Mar 29, 2015 | 09:11 PM
  #46
bealljk's Avatar
bealljk
the manifold is way too restrictive itself for an intake to really have any gains.
(I know it was 3 years ago) but great post...tip of the hat...
everyone throws on intakes/exhaust and dont see gains...
I wish an aftermarket would make a side-fed manifold (rather than the rear) where bank 1 doesnt take the majority of the intake/lean-out and cylinder 1 & 2 arent starved...hmmm...
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
