borla exhaust problems
Old Mar 14, 2012 | 06:52 PM
Johnking's Avatar
Johnking
Default borla exhaust problems
i just installed my borla td exhaust and it is making this random buzzing noise when downrevving and i have no clue what it is. I have taken it to a muffler shop and its not the a leak soo any ideas wht it could possibly be??
Old Mar 14, 2012 | 07:13 PM
-Trav-'s Avatar
-Trav-
Is the H pipe welded in?
Old Mar 14, 2012 | 07:16 PM
Johnking's Avatar
Johnking
i think thing every thing but the middle is... not sure i was think about taking out the h pipe and straight piping it back ive already removed the resonators cause they were causing some of the buzzing noise but as of this point idk wht else to do to solve the problem
Old Mar 14, 2012 | 07:26 PM
-Trav-'s Avatar
-Trav-
Youll probably lose a little power if you straight pipe it all the way back, you want to keep some kind of crossover.
I have mine fully welded and there are no problems. Some may not recommend this since If I want it removed Ill have to chop it all up, but no funny noises coming out of mine. Ive heard that the H pipe is a major source of such noises, Id have them weld it in or at least inspect more thoroughly. Get a different shop to look this time.
In regards to the resonators being removed, youll get a lot of rasp when you get on the throttle if you do this, especially above 3500 rpm. Is this the noise youre talking about?
Old Mar 14, 2012 | 07:35 PM
Johnking's Avatar
Johnking
ok might have to try tht out but noo its not the raspy sound i like tht its just this noise it buzzes when the engine is down revving and possibly while revving up as well cant really tell
Old Mar 14, 2012 | 07:37 PM
Dallasmavs92's Avatar
Dallasmavs92
Got test pipes?
Old Mar 14, 2012 | 07:38 PM
Johnking's Avatar
Johnking
i also have stillen high flow cats and i didnt replac the gaskets on them wheninstalling them and way ht could be a problem or am i over analyzing
Old Mar 14, 2012 | 07:41 PM
Johnking's Avatar
Johnking
sorry typig ws a little messed up.... its a little late
Old Mar 15, 2012 | 03:16 AM
CircleHeartX's Avatar
CircleHeartX
Its normal on the borla... Mine dose it when i rev it and let go, you can hear it like a second right after you release the pedal. Guess Thats Borla for you.
Ther has been lots of discussions on that Topic before guess its the H pipe?
Old Mar 15, 2012 | 03:22 AM
CircleHeartX
you can always add the magnaFlow X pipe Muffler. I have it and have never installed it hahaha been like 3 years now. Also have TurboXS test pipes, i need to install those as well.
Been planing on installing my test pipes soon, hopefully... this time for reals! lol
Old Mar 15, 2012 | 05:46 AM
Ronin82's Avatar
Ronin82
by buzzing, are you speaking of the loud "hissing" sound when the rev's decelerate, heard at low speed 3000 rpm's to idle.???
Old Mar 15, 2012 | 11:58 AM
Johnking's Avatar
Johnking
From Wht I'm hearing they do it a lot does anyone know if the magnaflow xpipe would eliminate the buzzing. And to the guy who asked the buzzing is at all times when it decelerates revving
Old Mar 15, 2012 | 12:03 PM
doshoru's Avatar
doshoru
It's most likely the H Pipe. The H pipe on a borla is actually two pieces that you clamp together. The connecting pipe doesn't fit very snuggly, and the clamp sucks. Over time, the two parts will rattle together. This is what happened to mine, and yes, it is a very common problem. Just have it welded....should only cost like $30. Cheaper than buying a whole new X-pipe.
Old Mar 15, 2012 | 02:19 PM
Johnking's Avatar
Johnking
I have everything welded besides the center of the h pipe soo would tht be tht problem ?
Old Mar 15, 2012 | 03:27 PM
-Trav-'s Avatar
-Trav-
This could definitely be a problem..I had a nasty buzz/rattling sound coming out of mine when decelerating due to old worn gaskets. You should always replace these when changing out exhaust parts, dont reuse.
Old Mar 15, 2012 | 03:57 PM
Johnking's Avatar
Johnking
Soo replace the gaskets and weld the center of the h pipe? Hopefully tht helps I'll keep you guys posted
Old Mar 15, 2012 | 05:20 PM
doshoru's Avatar
doshoru
Could be lots of things, really. But when somebody says the words "Borla" and "rattle" it is usually the center of the H pipe. I had never heard of this problem when I first assembled my Borla, but could tell just by looking at it that it was a weak point. The pipes didn't fit together well -- very little "overlap" for the clamp to work on.
Old Mar 27, 2012 | 04:14 PM
Johnking's Avatar
Johnking
new gaskets are installed and the noise is still there wht should i do? im thinking magnaflow x pipe but idk if thts going to solve the problem?
Old Mar 27, 2012 | 04:17 PM
Johnking's Avatar
Johnking
and yes it is a hissing noise tht would be a good way to describe it
Old Mar 29, 2012 | 01:56 AM
CircleHeartX
the H pipe is the hisssssrrRRrrRrRRr....
