small dent in intake
Old Jul 30, 2012 | 05:07 PM
ksuberk54's Avatar
ksuberk54
Default small dent in intake
Thinking about buying this momentum performance cold air intake from this dude for real cheap. The only problem is that it has a really small dent in it on the second intake pipe. I tried to upload the photo but it's not working but you can hardly tell. My question is: Does a small dent hurt performance or anything? I'm going to get it for less than 150 and he used it for 4k miles. is it a good buy? Thanks in advance.
edit: here's some photos.
Old Jul 30, 2012 | 05:57 PM
f150intally's Avatar
f150intally
-.76whp. No big deal mang.
R3belzBRN's Avatar
R3belzBRN
i dont think it will affect anything.
Old Jul 30, 2012 | 06:15 PM
ImWeeZzel's Avatar
ImWeeZzel
no br0 thats gunna throw a CEL code and put you in limp mode if you push it
Old Jul 30, 2012 | 06:18 PM
jeffie7's Avatar
jeffie7
Make sure you run defoulers, without them you'll throw a code.
Old Jul 30, 2012 | 06:48 PM
350ZZJoe's Avatar
350ZZJoe
^^ Is there an echo in here?
Entaille's Avatar
Entaille
it will still work fine but the air flow won't be 100% optimal.
Old Jul 30, 2012 | 06:49 PM
Entaille's Avatar
Entaille
spammer account. report it. : P
Old Jul 30, 2012 | 06:55 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
You won't notice any difference at all.
Old Jul 30, 2012 | 07:02 PM
padilla03z's Avatar
padilla03z
What exactly is a defouler?
Never mind I got it
Old Jul 30, 2012 | 07:09 PM
jeffie7's Avatar
jeffie7
It goes into the exhaust O2 sensor holes to help smooth out any turbulence caused by an imperfect intake.
Look at the dent as being a foul, and the defoulers cancels out that dent.
bbs350z's Avatar
bbs350z
its a non fouler. basically what you have to do is drill out that dent as large as possible, tap it, and thread in a non fouler so you throw any codes because the maf sensor is extremely sensitive. just make sure you dont pinch your throttle cable in the process.
Old Jul 30, 2012 | 07:21 PM
padilla03z's Avatar
padilla03z
Well it's my intake and it doesn't throw any codes in my car. Is there a reason it would change from car to car?
Old Jul 30, 2012 | 08:25 PM
jeffie7's Avatar
jeffie7
Maybe you bought your car used and it came with defoulers?
Old Jul 31, 2012 | 01:58 AM
padilla03z's Avatar
padilla03z
It has no defoulers. I've been all over my car and changed all my piping. Took this intake off because I put a turbo on
Old Jul 31, 2012 | 05:37 AM
cubs4worldseris's Avatar
cubs4worldseris
It will be fine, buy it
Old Jul 31, 2012 | 12:17 PM
abui01's Avatar
abui01
Google up "mandrel bent piping." Having a kink in a perfectly mandrel bent pipe introduces friction in the airflow. The computer is expecting a smooth rate of return based upon your throttle pressure. If this rate is disrupted by any dents/imperfections in the piping, then by definition the airflow is disrupted which could put your car in limp mode. It may or may not happen, but see if you can get a discount on the off-chance you may need to tow your car home if a major CEL is triggered which could possibly cause catastrophic engine damage.
Old Jul 31, 2012 | 01:12 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
+1
I think you should be good OP!
Old Jul 31, 2012 | 01:19 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Take this advise from the best story teller on this forum.......bar none.
Old Jul 31, 2012 | 01:29 PM
padilla03z's Avatar
padilla03z
If he has problems I'll take it back. I don't think he will have problems.
