ART Pipe Questions and Issues
Old Jan 10, 2014 | 09:23 AM
Lonestarr350's Avatar
Lonestarr350
Originally Posted by kingdom
lol i just got art pipes too. Picking up the car today, very excited.
Did you need to get non foulers for it ?
Old Jan 10, 2014 | 09:31 AM
travlee's Avatar
travlee
Master
you shouldnt need them....
Old Jan 10, 2014 | 09:33 AM
Lonestarr350
Okay cool ! I didn't think so ! But my friends told me I did .. I just wanted to dble check lol
Old Jan 10, 2014 | 11:52 AM
DankZ07's Avatar
DankZ07
They have integrated non-foulers. i.e. moving the 02 sensor farther from the exhaust flow.
That being said, my CEL is on, due to the ART pipes. Am I worried about it....nope.
Old Jan 10, 2014 | 02:05 PM
travlee's Avatar
travlee
Master
go get a tune.... problem solved. but wait until you do all breathing mods
Old Jan 13, 2014 | 04:53 AM
kingdom's Avatar
kingdom
https://soundcloud.com/afclemen/2005...art-test-pipes
There is another thread about art pipes floating around where someone points out that the "whooshing" sound comes from having art pipes ONLY.
It can be amended with the XYZ Pipe.
I have ART pipes ONLY, and I do notice the whooshing but it doesn't bother me that much. Many people complain about the rasp but thats the reason I got test pipes. Give the exhaust sound a lil character.
Old Jan 13, 2014 | 04:59 AM
travlee's Avatar
travlee
Master
you will hear that with just plain ol test pipes also, it is because there is nothing there to restrict the flow of the exhaust like there is in a cat
Old Jan 13, 2014 | 05:35 AM
kingdom's Avatar
kingdom
yes. There is also a sound of quickly moving air (similar to aftermarket intake sound) when I let off the gas quickly. I wonder if that's with all test pipes or just ART pipes, I though perhaps its the air leaving the side chamber when the pressure drops.
Old Jan 22, 2014 | 09:21 PM
Lonestarr350
Default ART pipe question ......!!!!
I had my installed art pipes today .. They look real nice on my Z! Lol .. Anyways .. My question is about the sound they're suppose to make .. Mine sounds like something is "rattling" when I'm steppin on the pedal and going over 3k rpm .. Is it suppose to make a sound like that or is it just suppose to be a "hiss" sound? .. The guy at the shop wasn't able to take off one of the o2 sensors off .. So I'm on one o2 sensor ( ima try to take it off my oem pipe tomorrow ) .. Is it cuz I only have one sensor on .. Or what?! Please help ! Thanks in advance !!
Old Jan 22, 2014 | 09:53 PM
drvqz33's Avatar
drvqz33
Sounds like the guy who installed em sucked if he couldn't find ways to take the o2 sensor out. Anyways, it sounds like it might be something from your exhaust making contact with something else. Have you checked underneath?
And I would get that o2 on asap.
Old Jan 22, 2014 | 09:59 PM
Lonestarr350
I'm about to check tomorrow morning cuz it's really "rattly" .. I been reason that it might be some bolt that sticks out and touches the pipes so it makes that sound .. Ima check and I will try to get that sensor off my oem pipe .. I think I need to use that pb blaster stuff ..
Old Jan 22, 2014 | 10:23 PM
michaelmoon912's Avatar
michaelmoon912
Probably the heat shields, bend them out of the way and problem solved.
Old Jan 22, 2014 | 10:33 PM
Lonestarr350
Will I need to take everything off to do that ?
Old Jan 23, 2014 | 02:45 AM
travlee's Avatar
travlee
Master
there is a bolt that you will need to cut off, cant remember which side, i think drivers. i have a rattle on mine also and it is the heat shield as others have said.. get the car up on stands and get under the car with a pry bar and wherever it is close just bend it some
Old Jan 23, 2014 | 03:12 AM
Sick an Twsd's Avatar
Sick an Twsd
Its the driver side bolt above the resonator, it needs to be trimmed down, had the same issue.
Old Jan 23, 2014 | 07:17 AM
Lonestarr350
Thanks Man! Appreciate it !
Lonestarr350
I'll need to check then if they guy did it lol appreciate it !
Old Jan 23, 2014 | 04:31 PM
  #38
Lonestarr350
Default Art pipe buzzin!!!!!! ANNOYED !!!!!
I still can't pin point that ANNOYING buzzin sounds wit my art pipes ... I checked the bolt on the driver side .. It was shaved enough .. So I tried check the heat shield and it doesn't seem to be touchin the pipe !!! Wtf !!! If anyone can maybe post a pic or somethin of where the buzzin is comin from is really appriciate it !! Cuz I'm annoyed and I've only had the pipes in for 2 days !!
Old Jan 23, 2014 | 05:09 PM
  #39
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I'd call Tony
Old Jan 23, 2014 | 05:16 PM
  #40
Lonestarr350
Originally Posted by 2004Black350z
I'd call Tony
I think I'll have to do that!
